Full Version: Rear trunk floor pan installation
Jgilliam914
After seeing all the work people have done to make their cars as rust free as possible. I decided to do my part. The rear trunk floor pan was " repaired " when I got the flares installed 28 years ago. I thought the body man had removed the original metal and replaced it with a flat piece just slightly above it. When in reality he just welded a piece over the top and left the original pan in place. Although it has stayed dry for these past few years I couldn't allow myself to continue without tearing out the original and the " fix ". So today I get the replacement part from restoration design and have it 90% installed and welded up.
The question I have is the heat shield. Is it needed to provide it's original use to keep heat out of the trunk or is it added weight?
914Sixer
A BIG YES ! Keep the heat shield.
JimN73
the heat shield deflects a phenomenal amount of hear. If we could figure out how to capture it, we could all put in headers and get rid of the old heat exchangers.
worn
QUOTE(JimN73 @ Apr 11 2013, 06:03 PM) *
Any ideas about finding replacements? Mine is rusting out.
Black22
The PO of my car cut the heat shield in half for a crappy exhaust install. I replaced my rear trunk pan and left it out. I have the pad and carpet in the trunk and its been fine for years.
It would be fine without it, depending on what exhaust you run.
Jeff Hail
Go find a wrecked late model Nissan Altima, Honda or Mercedes. Above the muffler you will find these two ply aluminum honeycomb heat shields. Same length as the 914 and about 2 inches wider. Only weights 9 oz compared to the factory heat shield boat anchor. Weld or bolt some 1 inch standoffs under the floor and you have a trick shield and lose some weight. Mercedes uses them just behind the qtr panels and they cost about $28.00 -they are formable.
993's and 996's uses the same material attached to the rear bumper reinforcements to keep the bumper cover from melting.
Spoke
I removed the heat shield to repair the trunk floor then decided to make it removable so I welded bolts to the hangers and bolted it in. I've already removed it a couple of times to repair some rear-end damage and to paint.
rudedude
my 70 4 cyl never had one, the 6 does. Did karmann forget to put it in that afternoon after a few beers at lunch?
914Sixer
Most of the early 70's year model 4 and 6 had bolted in heat shields. The boys at Osnabruck might have had a few extra beers at lunch.
76-914
QUOTE(Jeff Hail @ Apr 11 2013, 09:29 PM) *
That's a Hell of a fine idea. And the OG shield is heavy.
Any idea how much one really weighs?
Krieger
Mine has been gone for years. No problems, but not a daily driver. Paint in trunk is fine. Probably weighs 3 lbs
Jeff Hail
I just tossed a rusty one in the trash. More like 10 pounds.
