1st auto-x next weekend, Next AX September 8th- only 7 points out of 3rd place with 3 events left! |
scott_in_nh |
Apr 13 2013, 05:56 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
74, stock 2.0, stock front swaybar - no rear bar, stock front inserts, may mount an older set of adjustable Koni's I already have on the back, either way 100 lb springs, 195/65 Eagle GT's.
Looking to have fun, not too worried about much else, but I have a few basic setup questions: I'm going to chalk the tires, but what pressure should I start at? Full tank, half tank or empty tank? Spare tire in or out? The konis need to be adjusted out of the car - soft, medium or firm (keep in mind I will have to live with it on NH streets too)? Should I overfill the oil a bit? If so how much? What am I missing? Thanks, Scott |
mskala |
Apr 14 2013, 06:42 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Hi Scott,
If you're talking about NCR, barring car problems I will be there. Look for this thing: I think Chris has the bases covered. They usually have a large number of runs for the day and always have instructors for each group. Before you leave home check that the battery is secured well and check the CV joint bolts. Mark S. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:46 PM |
