| Rbcm2005 |
Apr 16 2013, 08:40 PM
Newbie ![]() Group: Members Posts: 49 Joined: 14-January 12 From: Nor. Cal. Member No.: 14,003 Region Association: Northern California |
Please help! So we had our car out for the first time following its resurrection from the dead with the stainless steel fuel lines and the relocation of the fuel pump complete.
All was good until we noticed a small fuel leak from under the tank. So we removed the tank tightened everything up, fired up the engine but then could tell that this time around we had some fuel lines kinked up as the fuel supply was now erratic. We pulled the fuel pump out from its new home up front behind the access panel several times but had trouble finding a good position where all the lines were again running freely. You could hear the turbulence in the lines and hear the pump straining a bit. Unfortunately after several attempts the pump just quit trying. (IMG:style_emoticons/default/WTF.gif) Damn! So my first thought was that we fried our pump. We removed it and hooked it up directly to another battery that we had. Gave it a quick jump and it is pumping away humming along just fine. Ok good. So then our next thought was the relay in the engine compartment. So we checked it but you can both hear and feel it click over when the ignition key is turned. So now I assume that means the relay is ok. Just in case we popped in a new one and it too appears to be clicking over on ignition. Finally we checked the voltage at the pump and get nothing with the turn of the key. At this point then in summary what I think I have is a good pump, a good relay but no power going to the pump. What do we check now?!?!?!?! Thank you in advance! (IMG:style_emoticons/default/beerchug.gif) |
| timothy_nd28 |
Apr 16 2013, 08:45 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
The FI system Ljet?
| Rbcm2005 |
Apr 16 2013, 08:49 PM
Rbcm2005 Fuel pump not getting power Apr 16 2013, 08:40 PM
The Cabinetmaker Did you check the fuse on the relay board in the e... Apr 16 2013, 08:45 PM
Rbcm2005
Did you check the fuse on the relay board in the ... Apr 16 2013, 08:51 PM
type47
Is there a fuse in addition to a relay in the eng... Apr 17 2013, 06:39 AM
The Cabinetmaker
[quote name='The Cabinetmaker' post='1851127' dat... Apr 17 2013, 07:04 AM
914itis Yes , there is a fuse on the relay board. Also rep... Apr 16 2013, 09:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 08:18 PM |
