> FI fuel presure, Green injector spec
gunny
post Apr 17 2013, 04:36 PM
I am running very lean and want to raise the fuel presure to richen it up. How high can I raise it safely? Does anyone know the spec range for the green injectors?
Dave_Darling
post Apr 17 2013, 10:49 PM
914 Idiot
32 PSI should be safe.
Increasing the pressure should richen the mixture across all conditions. It probably won't be by an equal amount in all conditions.
The ECU knob only affects the idle mixture.
You can add resistance to the intake air temp sensor (or just unplug it) to enrich the mixture slightly, or add resistance to the head temp sensor circuit to enrich it more.
--DD
- Lo-Fi Version Time is now: 5th March 2026 - 06:53 AM
