| 76-914 |
Apr 17 2013, 06:57 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I tried to install new brake lines today but apparently I need help. The old lines are S/S and are being replaced w/ rubber Meyle's. The old line has a small end on each end whereas the Meyle has one small and one large. (IMG:style_emoticons/default/WTF.gif) It fit's tightly on the hard line off the caliper but loose as a goose on those 1/2 union fittings which are both a bit smaller.
old n new ![]() different size ends ![]() ![]() I have more pic's if needed. The size difference is appx .020. Attached image(s)
| Elliot Cannon |
Apr 17 2013, 11:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
If you don't use the union, don't you have two female fittings? One on the hose and one on the car?
| type47 |
Apr 18 2013, 11:19 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
| Elliot Cannon |
Apr 18 2013, 12:54 PM
...don't you have two female fittings? One on the hose and one on the car? doesn't the hard line have a captured male threaded nut to screw into the female end of the rubber line? ![]() So no double female seeing each other.... I think you're right but what size is it?? |
76-914 Well, It's Come to This Apr 17 2013, 06:57 PM
'73-914kid Just dab a dollop of black RTV on the hose, and le... Apr 17 2013, 08:04 PM
Elliot Cannon Wait a minute! German auto part, made in Ital... Apr 17 2013, 11:14 PM
76-914 Thx, makes sense. Duh! Technically speaking, t... Apr 18 2013, 08:11 AM
bare 1 Technically there are no unions in the line. Diff... Apr 18 2013, 01:19 PM
76-914
Technically there are no unions in the line. Dif... Apr 18 2013, 04:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 01:23 AM |
