> How much horsepower is too much?, for a road car....
tadink
post Apr 19 2013, 05:28 PM
Hey all -
I've been looking at options for increased HP and have run across some crazy stuff, and that got me thinking about "how much is too much"?
This would be an occasional track car, AX often, mostly street, preferably reliable.
I've seen recently, in no particular order: 3.2L pretty stock, 3.3L race prepped turbo, 2.7 or 2.8 race prepped, v-8 twin turbo (IMG:style_emoticons/default/confused24.gif) , and other various mixes of suby-turbo, McMark's turbo 1.7L project, etc etc.
so, for you high HP guys out there - when does the car get just too silly to be practical on the street? 300bhp? 400bhp? 600bhp? 900bhp?
and what makes it not so enjoyable to drive around 'normally'? One guy described his 2.7 race engine as just too high strung for the street - - - so that means that you have to get into higher revs to get the power from the cam? (IMG:style_emoticons/default/confused24.gif)
edumacate me pls......
td
J P Stein
post Apr 23 2013, 12:04 AM
Irrelevant old fart
Brit finally blew the 901 ....12 inch slicks on concrete at a pro solo.
I finger that 350ish hp/torque was too much.....for the trans.
Add a bunch of power to a 914 and all you'll get is tire smoke. Couple that with tires and then you find the weak spots in the drive train and chassis limitations. Work at that long & hard and you'll find suspension limitations.
IMO, the answer to the original question is "As much as you can use"
Rand
post Apr 23 2013, 11:48 AM
Cross Member
QUOTE(J P Stein @ Apr 22 2013, 11:04 PM) *
Bingo. The the best concise answer for sure!
The tough question is, how much can you use. I guess that's what this thread is really about.
tadink   How much horsepower is too much?   Apr 19 2013, 05:28 PM
rick 918-S   350+ doesn't seen to ben an issue... :assimil...   Apr 19 2013, 05:49 PM
iamchappy   I think 400 is fine, takes a little getting used t...   Apr 19 2013, 05:53 PM
GeorgeRud   As Mark Donahue stated, "when I can spin the ...   Apr 19 2013, 06:07 PM
kg6dxn   Autocrossing with big HP in a small car is a chall...   Apr 19 2013, 06:16 PM
euro911   Shit, I'm happy with 125 :D ... ......   Apr 19 2013, 06:21 PM
The Cabinetmaker   Richard Fisher has about600 in his car. I've r...   Apr 19 2013, 06:25 PM
ConeDodger   225HP is very fun and streetable... Idles well, ha...   Apr 19 2013, 06:56 PM
carr914   Depends on the car & what the Induction is. I...   Apr 19 2013, 07:08 PM
ThePaintedMan   Then there is the Driver Equation! The fact t...   Apr 21 2013, 05:38 PM
iamchappy   When i built up my car i did it because i wanted t...   Apr 19 2013, 07:18 PM
JmuRiz   Just my thoughts...I'll have more insight late...   Apr 19 2013, 09:09 PM
messix   imho it's how the power is made. a high strun...   Apr 19 2013, 09:10 PM
Madswede   imho it's how the power is made. a high stru...   Apr 19 2013, 10:28 PM
Dave_Darling   I think the answer to "how much power do you ...   Apr 19 2013, 09:24 PM
Spoke   282HP is enough to get me pulled over by the PA St...   Apr 19 2013, 09:46 PM
McMark   I think 175-225 is the sweet spot. More than that ...   Apr 19 2013, 09:57 PM
Andyrew   Autox? You wont get much benefit from over 250hp g...   Apr 19 2013, 10:29 PM
Cap'n Krusty   Hmmmmmm. A wise and admired driver once said some...   Apr 19 2013, 11:24 PM
messix   "if everything seems in control, you're j...   Apr 20 2013, 12:39 AM
SirAndy   "how much is too much"? I've been i...   Apr 20 2013, 04:36 AM
Phil Plummer   "how much is too much"? I've been ...   Apr 20 2013, 08:39 AM
pcar916   An hour after I "finished" installing my...   Apr 20 2013, 07:47 AM
gothspeed   I usually think about it in power to weight and ho...   Apr 20 2013, 11:12 AM
messix   an all alloy ls series v8 is not much heavier the ...   Apr 20 2013, 11:40 AM
mr914   Simple answer by the late and great.   Apr 20 2013, 01:14 PM
r_towle   I,m sorry, is this a trick question? I don't ...   Apr 21 2013, 06:22 PM
johannes   The 914 is a very light car compared to modern pan...   Apr 22 2013, 05:36 AM
badmiata   The 914 is a very light car compared to modern pa...   Apr 22 2013, 03:02 PM
johannes   So a Subaru Sti with 300hp / wrx trans and gt fla...   Apr 23 2013, 06:46 AM
gothspeed   The 914 is a very light car compared to modern pa...   Apr 22 2013, 10:06 PM
sean_v8_914   horsepower and money... "I,m sorry, is this a...   Apr 22 2013, 07:59 AM
JmuRiz   I would think that would weigh more, closer to the...   Apr 22 2013, 03:47 PM
a914622   Well I will pipe in. Its not the hp its the tork b...   Apr 22 2013, 10:45 PM
J P Stein   Brit finally blew the 901 ....12 inch slicks on co...   Apr 23 2013, 12:04 AM
Rand   "As much as you can use" Bingo. The t...   Apr 23 2013, 11:48 AM
rfuerst911sc   I have aprox. 225 hp out of my 3.0 SC motor in my ...   Apr 23 2013, 03:41 AM
DBCooper   A lot of wisdom in the answers here. I have proba...   Apr 23 2013, 06:28 AM
carr914   The 914 is a very light car compared to modern pa...   Apr 23 2013, 06:33 AM
johannes   Except you didn't factor in the Weights of t...   Apr 23 2013, 06:40 AM
carr914   Except you didn't factor in the Weights of ...   Apr 23 2013, 07:04 AM
johannes   Maybe I'm missing something :huh: example;...   Apr 23 2013, 07:31 AM
gothspeed   I don't know what years johannes used but the ...   Apr 23 2013, 07:27 AM
J P Stein   The Shitbox had 200hp RWHP and weighed 1725lbs. N...   Apr 23 2013, 07:36 AM
Woody   The Shitbox had 200hp RWHP and weighed 1725lbs. ...   Apr 23 2013, 10:36 AM
carr914   Whats inertia and where can I buy some? :blink...   Apr 23 2013, 10:47 AM
Cupomeat   I remember that when the Porsche 928 GTS came out ...   Apr 23 2013, 12:00 PM
Rand   There's never too much power, but there most c...   Apr 23 2013, 12:34 PM
shuie   1300 is probably too much. IMHO. YMMV.   Apr 23 2013, 01:07 PM
Jgilliam914   A friend of mine had a 1971 Hemi Cuda with dual qu...   Apr 23 2013, 01:13 PM
Randal   Best all around engine for a street car is a 3.6 I...   Apr 23 2013, 01:24 PM
tadink   Great discussion - thanks for all who have contrib...   Apr 23 2013, 10:03 PM
Andyrew   What color was it, anything you can describe about...   Apr 23 2013, 10:07 PM
tadink   What color was it, anything you can describe abou...   Apr 24 2013, 04:56 AM
J P Stein   The 2.7L in the shitbox was good AX motor......10....   Apr 24 2013, 08:44 AM
FourBlades   My variation on the question is what tire, brakes,...   Apr 24 2013, 09:03 AM
iamchappy   To much is when you things start to break.....   Apr 24 2013, 09:26 AM
McMark   Great perspective, John! :clap: More clearly ...   Apr 24 2013, 09:29 AM
- Lo-Fi Version Time is now: 3rd July 2025 - 03:19 AM
