Cylinder head baffles, How important? |
PDXMike |
Apr 23 2013, 10:51 PM
Slowly Learning Group: Members Posts: 111 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
I am missing one of my cylinder head baffles. How big of a problem is this? I assume it effects airflow, but can I get by without it?
It looks like I would need to remove the pushrod tubes to get this in place. Is that right? Can I do this without dropping the engine? Thanks, Mike |
Mark Henry |
Apr 23 2013, 11:06 PM
Very important! It's what directs air over the bottoms of the cylinders.
Yes you can do this in the car. You will need 4 inner and 4 outer pushrod seals, remove the rockers, pushrods and tubes and you should be able to get the deflector in. You may be able to sneak it past the exhaust. Put it all back together and set your valves. |
reharvey |
Apr 24 2013, 06:15 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
Very important! It's what directs air over the bottoms of the cylinders. Yes you can do this in the car. You will need 4 inner and 4 outer pushrod seals, remove the rockers pushrods and tubes and you should be able to get the deflector in. You may be able to sneak it past the exhaust. Put it all back together and set your valves. (IMG:style_emoticons/default/agree.gif) These are easy to find so pick one up and install it. Ray |
Millerwelds |
Apr 24 2013, 08:28 AM
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
Just remember to note the location of each rocker and push rod so you can put everything back in the same exact location you pulled it from.
Lo-Fi Version | Time is now: 9th June 2024 - 11:39 PM |
