Finally Got around to Changing the Snorkel Tube, Another Mikey product rec'd,Today was time 2 Change it |
RON S. |
Apr 27 2013, 04:23 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Today was the day I mustered the energy to swap out my 43 year old rotten snorkel tube with the new one that I had gotten a month or so ago from Mikey.
The job is really a PITA (IMG:style_emoticons/default/headbang.gif) to the max, and then some. Be ready to spend most of the day on it, and have some help if you can get it. You'll really need 4 or 5 extra hands to push and pull and thread the wiring. I did mine alone, and it took me about 7 hours. First thing I noticed was that the Snorkel Tube is about 2- 2-1/2'' to long for my application. No matter, as I cut it in half about 3'' below the end that is the engine shelf grommet. Next was removing the interior, and since my wiring harness was already split in 2 on the shift tunnel, pulling it out was easy. With the wiring pulled up all the way into the engine compartment, I installed the 1st half I cut into the upper engine shelf. Once installed, which was a PITA doing it alone, I then threaded the harness back down through the upper Snork half, down below the engine. I then measured the bottom half of the elbowed end of the Snork tube, and cut about an inch off it. Then I threaded the wiring again through the elbowed piece and back into the car's interior. Once I got the bottom grommet of the snork Tube in place in the chassis, I rolled back the tubing on one end where the 2 halves and unrolled it over the other half. This gave the unit about 1-1/2 to 2'' of overlap on the tube. It sealed up really tight, and it looks pretty good. Re-plugged all the wires in, put the seats back in, and I was done. Time to go back to driving it. All in all, another great Mikey product. Thanks Mikey (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/thumb3d.gif) Attached thumbnail(s) |
Mikey914 |
Apr 28 2013, 10:27 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Ron,
Do you think it was any easier to thread through was a 2 part piece? Also, the seal between the 2 friction fit or silicone to seal it? Seems like friction fit would be adequate with a 1" overlap. |
RON S. |
Apr 28 2013, 11:57 AM
Ron, Do you think it was any easier to thread through was a 2 part piece? Also, the seal between the 2 friction fit or silicone to seal it? Seems like friction fit would be adequate with a 1" overlap. Mikey, It was definitely easier as a 2 piece unit, to get all the wiring pulled through. I probably had an advantage in that I have an engine access cover between my seats. With an engine in a car, and not having the access, it will mean hanging over one's engine with little or no eyesight to setting the upper grommet. Once I got the wiring through the bottom half, I rolled the edge of the Snorkel tube back like a condom. I rolled it back about 2 inches, and then worked the bottom grommet through the locating hole in the chassis. AFTER I reattached all wiring, and had everything laid in place where it'd stay forever, I then went back under the car, and un-rolled the bottom half of the tube, over the upper piece, creating about 1-1/2'' of overlap. It's pretty tight as it is, I'm not worried about any leaking. Besides, it's a much better look than what I had in there. If anyone is intersted in my old Snork tube, I'll give someone a good deal. (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 08:05 PM |
