No electrical power, Am I looking at an ignition switch failure ? |
jim_hoyland |
Apr 29 2013, 05:43 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
My '75 has started perfectly for many years; today that record ended. I had been checking my remote start button that mounts in the engine compartment. Started the car a couple of times. I then got in the car to move into the garage, turn the ignition key to acces position and NO dash lights, no accessories or lights would work. Turning the switch to the start position was useless.
The battery is good; I have power to the hot side of the fuse panel; the relays on the fuse panel are good.All the fuses are good as well An I correct that the ignition switch is fried ? Attached image(s) |
r_towle |
Apr 29 2013, 08:22 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I don't buy the ignition switch diagnosis.
You were using a remote start switch and things work. First, check the little red wires on the positive terminal at the battery. Remove them, clean them, then re install them nice and spring tight.... Mine needed that every year, no idea why, but it gets cleaned now. Rich |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:25 AM |
