yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,455 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
I'm starting to gather that my new VDO oil pressure gauge might not be all that great. Tonight (first time out at night) it was reading near 0lbs at idle, but the idiot light was not coming on (dual pole sender). Normally I see somewhere between 7-10lbs on the gauge when hot. My suspicion is that the voltage was lower (at idle) to the gauge because the headlights and what not were on.
I seem to remember RatWell saying these gauges weren't all that accurate, but being off by 10lbs is just silly. Gauge perked right up off idle and gave me well over 10lbs per 1K rpm. Are there any gauges that might be more accurate at the lower rpms than these? Aircraft Spruce is my favorite vendor for this stuff, but nothing they sell has any low PSI resolution in an electric gauge. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
QUOTE but being off by 10lbs is just silly Make sure you have a good ground from the sender unit to chassis. Or to be even more accurate, run a dedicated ground from the sender to the gauge, then ground that wire to chassis as close to the gauge as possible. I am building a new harness this weekend, and you just made me decide to add a couple of extra wires just for that purpose. Stu |
Lo-Fi Version | Time is now: 1st July 2025 - 06:43 AM |
