> VDO Oil Pressure Gauge Accuracy
yeahmag
post May 2 2013, 11:52 PM
I'm starting to gather that my new VDO oil pressure gauge might not be all that great. Tonight (first time out at night) it was reading near 0lbs at idle, but the idiot light was not coming on (dual pole sender). Normally I see somewhere between 7-10lbs on the gauge when hot. My suspicion is that the voltage was lower (at idle) to the gauge because the headlights and what not were on.
I seem to remember RatWell saying these gauges weren't all that accurate, but being off by 10lbs is just silly. Gauge perked right up off idle and gave me well over 10lbs per 1K rpm. Are there any gauges that might be more accurate at the lower rpms than these? Aircraft Spruce is my favorite vendor for this stuff, but nothing they sell has any low PSI resolution in an electric gauge.
MrHyde
post May 3 2013, 03:54 AM
(sorry to hijack)
Would you lose the idiot light if you were to use the Stack gauge and sender ???
ChrisFoley
post May 3 2013, 04:38 AM
I am Tangerine Racing
QUOTE(MrHyde @ May 3 2013, 04:54 AM) *
(sorry to hijack)
There's no need to lose the light. Add a tee on the end of the extension hose so both the stock sender and gauge sender can be installed.
bobhasissues
post May 3 2013, 07:07 PM
seemingly endless issues with my 914
[/quote]
[/quote]
Example of what Chris said in photo.
Attached Image.
But, I would be concerned that the idiot light was not triggered by the VDO. Most complaints are that the VDO triggers the idiot light at higher pressure than the idiot would normally trigger on it's own. If your idiot light is not lighting when you crank the car then it's not getting a signal from the VDO. From the installation shown in the photo, you get two independent opinions, one from the VDO sender and a second from the idiot light which is no longer dependent on the VDO sender
- Lo-Fi Version Time is now: 1st July 2025 - 06:12 AM
