1st auto-x next weekend, Next AX September 8th- only 7 points out of 3rd place with 3 events left! |
scott_in_nh |
Apr 13 2013, 05:56 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
74, stock 2.0, stock front swaybar - no rear bar, stock front inserts, may mount an older set of adjustable Koni's I already have on the back, either way 100 lb springs, 195/65 Eagle GT's.
Looking to have fun, not too worried about much else, but I have a few basic setup questions: I'm going to chalk the tires, but what pressure should I start at? Full tank, half tank or empty tank? Spare tire in or out? The konis need to be adjusted out of the car - soft, medium or firm (keep in mind I will have to live with it on NH streets too)? Should I overfill the oil a bit? If so how much? What am I missing? Thanks, Scott |
ChrisFoley |
May 8 2013, 10:51 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You can put 205s on 5.5" rims.
I have them on my street 914. |
ThePaintedMan |
May 8 2013, 10:58 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
You can put 205s on 5.5" rims. I have them on my street 914. Yup, and they look better in my opinion too. But it's a real tight fit, depending on the type of rim. With the EMPIs on our car, and with the car lowered a bit in the back, I've got about a pinkie's width of room to play with. |
scott_in_nh |
May 8 2013, 11:06 AM
You can put 205s on 5.5" rims. I have them on my street 914. Yup, and they look better in my opinion too. But it's a real tight fit, depending on the type of rim. With the EMPIs on our car, and with the car lowered a bit in the back, I've got about a pinkie's width of room to play with. Ok, I've seen some back and forth on this and it seemed that you could get them on, but some suggested you would not really get a benefit over 195's on such a narrow rim. My rims are the factory sport steel rims. If the consensus here is that they 1) will fit in the fender well without any real rolling of the fender (I don't mind a gently pull) 2) will be better than 195's then that is the way I'll go Next SCCNH event isn't until 6/2 so I have some time to find the money.... |
Lo-Fi Version | Time is now: 9th June 2024 - 08:50 PM |
