| moparrob |
May 5 2013, 08:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
So I decided I want a new sweatshirt and figured it would be cool (to me) to have an image of a Weber 40 IDA 3C carb on it, of which two reside on my 3.0 litre engine in my six conversion:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1367806864.1.jpg) So I dug around the internet and could not find any for sale, but I did find a stock exploded view - but of low quality. (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1367806864.2.jpg) I guess I would settle for that, but no one makes that either , as far as I can tell. Does anyone have any suggestions where to buy one, or how to have one made? I have seen custom sweatshirt sites but you would need to have a high(er) res image to send them, which I can't seem to find. Doesn't one of our member make t-shirts? Perhaps he can be bribed/persuaded to do a run? Any help is greatly appreciated. |
| moparrob |
May 5 2013, 08:53 PM
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler.
That's about it. Should be good for 200 HP. |
| rgalla9146 |
May 6 2013, 11:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. Hi Hate to pile on but please provide as much carb info as possible. Venturies, jets, emulsions, air corrections and anything else you can think of. Thank you Rory |
| Luke M |
May 6 2013, 01:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,497 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. Hi Hate to pile on but please provide as much carb info as possible. Venturies, jets, emulsions, air corrections and anything else you can think of. Thank you Rory I second that.. I'm in the same spot as Rory over here.. 83 3.0 with Weber 40's going into my brothers 914.. Plus any other things that you came across as a possible issue.. like wire harness or ignition. I'm aware of the clutch problem fitting onto a 901.. Got a PMS flywheel/disc kit coming. TIA, Luke |
| moparrob |
May 10 2013, 09:47 PM
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. Hi Hate to pile on but please provide as much carb info as possible. Venturies, jets, emulsions, air corrections and anything else you can think of. Thank you Rory I second that.. I'm in the same spot as Rory over here.. 83 3.0 with Weber 40's going into my brothers 914.. Plus any other things that you came across as a possible issue.. like wire harness or ignition. I'm aware of the clutch problem fitting onto a 901.. Got a PMS flywheel/disc kit coming. TIA, Luke Sorry about the delayed response guys - work has been busy.. Specs: 34 Main Venturies, 140 Main Jet, 160 Air Correction Jet, 60 Idle Jet, F3 emulsion tubes Talk to perry@qsnap.com for a custom wiring loom. He helped me to bypass my old relay panel and built a custom loom for the new distributor and MSD box. Awesome work! |
| rgalla9146 |
May 11 2013, 09:35 AM
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. Hi Hate to pile on but please provide as much carb info as possible. Venturies, jets, emulsions, air corrections and anything else you can think of. Thank you Rory I second that.. I'm in the same spot as Rory over here.. 83 3.0 with Weber 40's going into my brothers 914.. Plus any other things that you came across as a possible issue.. like wire harness or ignition. I'm aware of the clutch problem fitting onto a 901.. Got a PMS flywheel/disc kit coming. TIA, Luke Sorry about the delayed response guys - work has been busy.. Specs: 34 Main Venturies, 140 Main Jet, 160 Air Correction Jet, 60 Idle Jet, F3 emulsion tubes Talk to perry@qsnap.com for a custom wiring loom. He helped me to bypass my old relay panel and built a custom loom for the new distributor and MSD box. Awesome work! Thank you for the specs. Can you tell us ( I assume you've driven the car ) if there were adjustments to the carbs after driving it initally ? I'm not asking about mixture or balance but rather any jet changes, emulsions venturies etc. I ask because Bruce Anderson (RIP) specs 160 mains and 175 air corrections as a startup. Were changes done as a result of dyno tuning ? TIA Rory |
| Mark Henry |
May 11 2013, 07:32 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. Hi Hate to pile on but please provide as much carb info as possible. Venturies, jets, emulsions, air corrections and anything else you can think of. Thank you Rory I second that.. I'm in the same spot as Rory over here.. 83 3.0 with Weber 40's going into my brothers 914.. Plus any other things that you came across as a possible issue.. like wire harness or ignition. I'm aware of the clutch problem fitting onto a 901.. Got a PMS flywheel/disc kit coming. TIA, Luke Sorry about the delayed response guys - work has been busy.. Specs: 34 Main Venturies, 140 Main Jet, 160 Air Correction Jet, 60 Idle Jet, F3 emulsion tubes Talk to perry@qsnap.com for a custom wiring loom. He helped me to bypass my old relay panel and built a custom loom for the new distributor and MSD box. Awesome work! Thank you for the specs. Can you tell us ( I assume you've driven the car ) if there were adjustments to the carbs after driving it initally ? I'm not asking about mixture or balance but rather any jet changes, emulsions venturies etc. I ask because Bruce Anderson (RIP) specs 160 mains and 175 air corrections as a startup. Were changes done as a result of dyno tuning ? TIA Rory This jet info is OK to know as a baseline, but be sure that till you have actually tuned the carbs you will not know it's exact jetting requirements. Every engine will have different jetting requirements. I used this info to buy 34mm vents and F3 emulsion tubes (and rebuild kits) today. I'll be using a wide band to tune my carbs, with my WB and jet reamer kit I'll make my own jets. That said the Performance Oriented guesstimate on jetting comes from a lot of experience and I bet will be damn close. |
moparrob Wanted: Weber 40 IDA 3C sweatshirt May 5 2013, 08:21 PM
moparrob I'm going to have this one made up, but I was ... May 5 2013, 08:34 PM
Mark Henry Is everyone building 3.0's?
Engine specs plea... May 5 2013, 08:48 PM
6freak
stock 1978 large port 3.0, upgraded turbo cam cha... May 6 2013, 09:43 AM
moparrob
Unfortunately the engine has not yet been ins... May 11 2013, 06:06 PM
patssle
stock 1978 large port 3.0, upgraded turbo cam cha... May 11 2013, 10:14 AM
Mark Henry Sounds nice, those carbs must have cost you but at... May 6 2013, 06:26 AM
GeorgeRud Should be a nice runner. The SC cams and P/C don... May 6 2013, 08:00 AM
JmuRiz
Should be a nice runner. The SC cams and P/C don... May 6 2013, 08:50 AM
GeorgeRud I guess I'm old school, but I think these engi... May 6 2013, 09:14 AM
Mark Henry Crap I was thinking mine was going to be just over... May 6 2013, 10:18 AM
mskala I bought this design in a t-shirt version, but you... May 6 2013, 10:30 AM
moparrob
I bought this design in a t-shirt version, but yo... May 6 2013, 10:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:38 PM |
