| mskala |
Mar 7 2013, 09:07 PM
R ![]() ![]() ![]() Group: Members Posts: 1,967 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
I'd like to know if anyone else with -6 linkage has seen this. The last
piece connected to the bar at the trans lever has 2 separate contacts/ movements, and even though I didn't see a wear pattern they were both pretty sloppy. Below I'll show what I did for this. The top channel contacts the ball of the trans lever. It has 18mils of slop in it but the ball doesn't look worn. I decided the easiest thing to do was glue in a 26-gauge brass shim with some 3M super90. Perfect fit now. Even if this wears within a year or two, it's very easy to re-do and I'm under the car a lot anyway. But the fork side of the piece has HUGE slop. About 75 mils. It actually looks like maybe somebody ground the opening wider because the casting is smooth and rounded everywhere else. So, this slop was taken basically to 0-5 mils by welding it and re-grinding. Sorry the pictures are only after being greased. It's still snowing here so I won't even get to feel for improvement for a while. Shim: Side view after welding: ![]() Rear view: ![]() |
| toolguy |
May 11 2013, 08:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,277 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
The ball on mine was worn. . but I was able grab it with vise grips and turn it 90 degree. . I welded the other worn spots and machined them back to orig specs. .
All in all, it's a tailshifter and still has some play in it . |
mskala Shifter slop, 914-6 edition Mar 7 2013, 09:07 PM
Dr Evil So, how does it shift??? Mar 7 2013, 09:12 PM
mskala
Engine not ready to ru... Mar 7 2013, 09:33 PM
Cap'n Krusty Need another one of those? How about the nose cov... Mar 7 2013, 09:22 PM
Dr Evil I have a need for a /6 tail cone. Is this what you... Mar 7 2013, 09:30 PM
Mr.242 Interesting way to shim the gap. Wondering if it ... Mar 7 2013, 11:04 PM
Justin Fischer I have some wear on that piece but I haven't a... Mar 8 2013, 05:42 AM
pcar916 Will work just fine but a stainless shim would las... Mar 9 2013, 04:49 AM
mskala Well I've been driving the car a bit, and my v... May 11 2013, 07:41 PM
Dr Evil Yup, I convert a lot of /6 to side shifter for thi... May 11 2013, 09:24 PM
Cairo94507 Winner Winner Chicken Dinner! That's what... May 11 2013, 10:27 PM
Dr Evil Oh ya, the shipping was $32 ;) I forgot to co... May 11 2013, 10:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th November 2026 - 02:18 AM |
