Fabrication, Bracket for seat |
Randal |
May 14 2013, 06:34 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I've got to install a seat bracket before Cascade Lakes, otherwise I might not pass tech inspection.
Been looking at a number of different options. First of all here are a couple of pictures so you'll see how much space (and angles) I have to work with. Front view: From the back at the top: From the back looking down: Was thinking about making an L bracket that I can bolt to the seat (the 2.5" section between the holes for the seat belts. I'll use something like a carriage bolt with a rounded head on the drivers side of the seat. Found a couple of brackets for the roll bar that will work: Or use a couple of these with the same L bracket Coleman also makes a parallel one that might be easier to bolt up to the L bracket on the roll bar side. Good way or is there a better way. All ideas appreciated! |
brant |
May 15 2013, 02:26 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I built one about 15 years ago for PCA club racing
I decided to punch a hole in the firewall and build a bracket that slid through the firewall to the seat. It was adjustable with a pin in the engine bay because we had 2 drivers and needed an adjustable seat. my only thoughts about safety are: if a wreck bad enough to deform the roll bar occurs... the seat could move forward or backwards with the bar and cause the belts to get tight or loose... I know its not likely the roll bar would deflect, but you never know in a roll over situation. by tying the seat brace to the firewall it was tied into the same place as the belt mounts... I figured if the firewall moved at least the seat would deflect with the belts instead of independant... |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:07 AM |
