Fabrication, Bracket for seat |
Randal |
May 14 2013, 06:34 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I've got to install a seat bracket before Cascade Lakes, otherwise I might not pass tech inspection.
Been looking at a number of different options. First of all here are a couple of pictures so you'll see how much space (and angles) I have to work with. Front view: From the back at the top: From the back looking down: Was thinking about making an L bracket that I can bolt to the seat (the 2.5" section between the holes for the seat belts. I'll use something like a carriage bolt with a rounded head on the drivers side of the seat. Found a couple of brackets for the roll bar that will work: Or use a couple of these with the same L bracket Coleman also makes a parallel one that might be easier to bolt up to the L bracket on the roll bar side. Good way or is there a better way. All ideas appreciated! |
brant |
May 15 2013, 02:26 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I built one about 15 years ago for PCA club racing
I decided to punch a hole in the firewall and build a bracket that slid through the firewall to the seat. It was adjustable with a pin in the engine bay because we had 2 drivers and needed an adjustable seat. my only thoughts about safety are: if a wreck bad enough to deform the roll bar occurs... the seat could move forward or backwards with the bar and cause the belts to get tight or loose... I know its not likely the roll bar would deflect, but you never know in a roll over situation. by tying the seat brace to the firewall it was tied into the same place as the belt mounts... I figured if the firewall moved at least the seat would deflect with the belts instead of independant... |
Randal |
May 15 2013, 05:59 PM
I built one about 15 years ago for PCA club racing I decided to punch a hole in the firewall and build a bracket that slid through the firewall to the seat. It was adjustable with a pin in the engine bay because we had 2 drivers and needed an adjustable seat. my only thoughts about safety are: if a wreck bad enough to deform the roll bar occurs... the seat could move forward or backwards with the bar and cause the belts to get tight or loose... I know its not likely the roll bar would deflect, but you never know in a roll over situation. by tying the seat brace to the firewall it was tied into the same place as the belt mounts... I figured if the firewall moved at least the seat would deflect with the belts instead of independant... Good point about the roll bar deflecting and tightening or loosening the belts. In my case the bar behind is there only for holding the seat belts, i.e., the bar goes between the outside hoop and the engine tunnel hump, i.e., the hump between the seats. We welded in steel bases on the hump to attach the belt bar. In any event you got me wondering why SCCA requires such a brace. My only thought was that the brace was meant to keep the seat in it's upright position, but maybe there is another reason. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:05 PM |
