| Scott S |
May 15 2013, 11:43 AM
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All -
I am getting ready to replace the bushings on my weltmeister sway bar. The bushings I am referring to are the ones that are actually on the bar itself - not the drop links. I did a bunch of searching but did come up with much. Has any one done this? Once I remove the three bolts in the wheel well, do the bushings simply slide on and off of the bar? They are a pretty hard material. Thanks! Scott S |
| jmill |
May 15 2013, 09:26 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
I have a 22mm Welt bar and bought new bushings for it also. I haven't installed them yet. I will say that the larger bar will slide through one side and out the other with semi worn bushings. I highly doubt you need to split them with a large bar. If it's the smaller stock bar then you need to split them.
Scott S Replacing Weltmeister sway bar bushings May 15 2013, 11:43 AM
shuie http://www.914world.com/bbs2/index.php?showtopic=1... May 15 2013, 12:41 PM
r_towle Custom bronze, after I crushed the first set. May 15 2013, 09:27 PM
lrm914
Hi All -
I am getting ready to replace the bushin... May 17 2013, 09:50 PM
Scott S Hi Larry -
I got them from automotion (prepare you... May 20 2013, 11:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th June 2026 - 05:26 AM |
