> 2.0 Rebuild Advice Needed, 2056 or 2270?
john_g
post May 15 2013, 07:29 PM
I'm getting ready to rebuild my 2.0 and am considering going to either 2056, or maybe even up to 2270. What are the downsides or problems associated with going 2270, if any?
john_g
post May 15 2013, 11:52 PM
Another issue, in addition to the questions I have about reliability, longevity, heat, the possible need for an oil cooler, modifying the camshaft, etc. is about EFI. I'm currently running EFI. If I go with a 2056, I believe I can stick with the EFI, but I'll have to go with carbs if I increase to 2270, correct?
KELTY360
post May 16 2013, 02:39 PM
914 Neferati
QUOTE(john_g @ May 15 2013, 09:52 PM) *
Just to clarify, what EFI system are you currently running?
john_g
post May 16 2013, 05:18 PM
I'm running the stock EFI system.
QUOTE(KELTY360 @ May 16 2013, 01:39 PM) *
john_g   2.0 Rebuild Advice Needed   May 15 2013, 07:29 PM
r_towle   More work, worse rod ratio than a 2056. Higher cha...   May 15 2013, 07:40 PM
john_g   Why would there be a higher chance of ring wear? I...   May 15 2013, 10:49 PM
Jake Raby   Rod ratio is no worse if the engine is designed co...   May 15 2013, 08:59 PM
john_g   Jake, Isn't heat an issue with the 2270, as we...   May 15 2013, 10:48 PM
john_g   Another issue, in addition to the questions I have...   May 15 2013, 11:52 PM
KELTY360   Another issue, in addition to the questions I hav...   May 16 2013, 02:39 PM
john_g   I'm running the stock EFI system. Another i...   May 16 2013, 05:18 PM
porschefile2010   From my experience and having stuffed one engine a...   May 16 2013, 12:16 AM
rwilner   FWIW -- I went through this decision process last ...   May 16 2013, 06:10 AM
r_towle   Djet can handle more displacement, just not more s...   May 16 2013, 07:35 AM
john_g   Thanks, Rich. I must be a little slow, can you cl...   May 16 2013, 09:52 AM
r_towle   Thanks, Rich. I must be a little slow, can you c...   May 16 2013, 11:33 AM
john_g   Thanks, Rich, I get it now. And yeah, I've ha...   May 16 2013, 05:20 PM
AE354803   Djet can go up to 2.4 liter with the 71mm stroke...   May 17 2013, 03:25 PM
r_towle   [quote name='r_towle' post='1865025' date='May 16...   May 17 2013, 09:22 PM
Porschef   If I may chime in... I replaced my defunct 2.0 wit...   May 16 2013, 10:47 AM
Jake Raby   Its been over a decade since we had any thermal co...   May 16 2013, 09:25 PM
john_g   Its been over a decade since we had any thermal c...   May 17 2013, 09:36 AM
Jake Raby   Its been over a decade since we had any thermal ...   May 17 2013, 02:36 PM
john_g   [quote name='john_g' post='1865450' date='May 17 ...   May 17 2013, 05:30 PM
Jake Raby   Adding all that displacement when keeping the stoc...   May 18 2013, 12:18 PM
r_towle   I recall some testing that showed the intake runne...   May 18 2013, 01:15 PM
rwilner   I have read to many stories about Megasquirt and ...   May 21 2013, 01:07 PM
914_teener   I have read to many stories about Megasquirt and...   May 21 2013, 01:49 PM
Jake Raby   Of course you were.   May 18 2013, 01:42 PM
r_towle   Not everyone needs to follow you jake, we all have...   May 18 2013, 07:35 PM
Jake Raby   Not everyone needs to follow you jake, we all hav...   May 20 2013, 07:43 PM
gothspeed   To the OP, a 2056 or 2275 each have their virtues ...   May 18 2013, 08:11 PM
rhodyguy   1. dave hunt had nightmares trying to get even a m...   May 22 2013, 10:08 AM
- Lo-Fi Version Time is now: 9th June 2026 - 01:36 AM
