| Kerrys914 |
Jul 6 2004, 02:38 PM
Dear, the parts I just sold paid for that part ;) ![]() ![]() ![]() Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 |
Changed my oil this past weekend and fixed my non-working oil temp gauge (IMG:style_emoticons/default/smile.gif) The bad news is the dam taco plate is leaking oil now. Argggggggggggggggggggggggg (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
I had the engine sealed up nicely after the last oil change. The problem I made during the last oil change/sender install was I put sealant between the sender plate and the block. FYI the sender plate needs good contact with the block to work right (well at least mine does). Now I need to drain the oil and fix the leak and refill with new oil. (IMG:style_emoticons/default/headbang.gif) . Does anyone have a good solution for this nasty leak? I assume some good high temp sealant and a paper gasket is what is needed. FYI the leak is not coming form the bolts. Oh yea, I picked up a sealed battery from SAMS (IMG:style_emoticons/default/smile.gif) So someting did go right this weekend. (IMG:style_emoticons/default/driving.gif) Cheers Kerry |
| Joe Bob |
Jul 6 2004, 03:12 PM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
If it's synthetic, use a clean container and re-use the oil.....if it's dino oil....it ain't expensive.
Filters are cheap.....too. Why did you use a sealant? If it was OK before....clean it up and make sure the gland nut is tight. |
Kerrys914 Dam TACO plate :( Jul 6 2004, 02:38 PM
Andyrew Oh hey, almost the same problem as me.. but I had ... Jul 6 2004, 03:03 PM
Kerrys914 I used sealant before. Must have been just the rig... Jul 6 2004, 05:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th June 2026 - 03:36 PM |
