> 2.0 Rebuild Advice Needed, 2056 or 2270?
john_g
post May 15 2013, 07:29 PM
I'm getting ready to rebuild my 2.0 and am considering going to either 2056, or maybe even up to 2270. What are the downsides or problems associated with going 2270, if any?
r_towle
post May 16 2013, 07:35 AM
Custom Member
Djet can handle more displacement, just not more stroke.
Up to 2.4 liter as far as I know.
BUT
I would suggest if heat is another one of your concerns, stick with the 2056.
Bigger displacement of much more than that may require external oil cooling and if you stroke it, it will require a new induction system.
Carbs run maybe 1k all in.
EFI could be 2k all in, and I have not seen a decent bolt on application for these motors, so you will be doing custom tuning, and custom wiring etc.
Rich
john_g
post May 16 2013, 09:52 AM
Thanks, Rich. I must be a little slow, can you clarify something for me? You're saying that the D-jet can handle it, but will need custom tuning, wiring, etc. to the tune of an additional 2K, right?
And the 2056, doesn't require major modifications to the EFI?
QUOTE(r_towle @ May 16 2013, 06:35 AM) *
BUT
Rich
r_towle
post May 16 2013, 11:33 AM
Custom Member
QUOTE(john_g @ May 16 2013, 11:52 AM) *
BUT
Rich
Djet can go up to 2.4 liter with the 71mm stroke (stock) crank.
That is 103mm pistons.
It cannot deal with a longer stroke.
for the 2270, that is a stroker motor with 96mm pistons and a 78mm crank (stock is 71mm)
That motor (the one you are asking about) requires a custom EFI system with new wiring etc...in the 2k range and there is no off the shelf system available, so you need to know what you are doing, or hire someone who does.
2056 is your best bet.
both the 2270 and the 2.4 liter stock stroke require external oil coolers.
Both motors are tuned and require more maintenance than a 2056 will ever require.
One thing to think about.
McMark (an admin here) has a shop names Original Customs and he will build a 2056 for you that is reliable.
rich
rich
AE354803
post May 17 2013, 03:25 PM
QUOTE(r_towle @ May 16 2013, 10:33 AM) *
rich
Rich, just a curiosity, why can't the Djet system deal with a longer stroke?
If the capacity of the engine is the same why would it matter whether it was because of a larger diameter or a longer stroke, the FI is most concerned with the flow of air into the engine? I would expect the flow rate of air into the cylinder to be essentially the same at a given RPM if everything else was identical.
You can see from the graph that the change in volume (flow) into cylinders follows the same basic path. (the 103 mm x 71 yields a larger displacement than 96 mm x 78.4 but even if it's changed to 101 mm it still follows approximately the same curve) You can see how the rod length affects the curve by essentially flattening it as length increases.
Again I have no idea, but this surprised me.
Andy
john_g   2.0 Rebuild Advice Needed   May 15 2013, 07:29 PM
r_towle   More work, worse rod ratio than a 2056. Higher cha...   May 15 2013, 07:40 PM
john_g   Why would there be a higher chance of ring wear? I...   May 15 2013, 10:49 PM
Jake Raby   Rod ratio is no worse if the engine is designed co...   May 15 2013, 08:59 PM
john_g   Jake, Isn't heat an issue with the 2270, as we...   May 15 2013, 10:48 PM
john_g   Another issue, in addition to the questions I have...   May 15 2013, 11:52 PM
KELTY360   Another issue, in addition to the questions I hav...   May 16 2013, 02:39 PM
john_g   I'm running the stock EFI system. Another i...   May 16 2013, 05:18 PM
porschefile2010   From my experience and having stuffed one engine a...   May 16 2013, 12:16 AM
rwilner   FWIW -- I went through this decision process last ...   May 16 2013, 06:10 AM
r_towle   Djet can handle more displacement, just not more s...   May 16 2013, 07:35 AM
john_g   Thanks, Rich. I must be a little slow, can you cl...   May 16 2013, 09:52 AM
r_towle   Thanks, Rich. I must be a little slow, can you c...   May 16 2013, 11:33 AM
john_g   Thanks, Rich, I get it now. And yeah, I've ha...   May 16 2013, 05:20 PM
AE354803   Djet can go up to 2.4 liter with the 71mm stroke...   May 17 2013, 03:25 PM
r_towle   [quote name='r_towle' post='1865025' date='May 16...   May 17 2013, 09:22 PM
Porschef   If I may chime in... I replaced my defunct 2.0 wit...   May 16 2013, 10:47 AM
Jake Raby   Its been over a decade since we had any thermal co...   May 16 2013, 09:25 PM
john_g   Its been over a decade since we had any thermal c...   May 17 2013, 09:36 AM
Jake Raby   Its been over a decade since we had any thermal ...   May 17 2013, 02:36 PM
john_g   [quote name='john_g' post='1865450' date='May 17 ...   May 17 2013, 05:30 PM
Jake Raby   Adding all that displacement when keeping the stoc...   May 18 2013, 12:18 PM
r_towle   I recall some testing that showed the intake runne...   May 18 2013, 01:15 PM
rwilner   I have read to many stories about Megasquirt and ...   May 21 2013, 01:07 PM
914_teener   I have read to many stories about Megasquirt and...   May 21 2013, 01:49 PM
Jake Raby   Of course you were.   May 18 2013, 01:42 PM
r_towle   Not everyone needs to follow you jake, we all have...   May 18 2013, 07:35 PM
Jake Raby   Not everyone needs to follow you jake, we all hav...   May 20 2013, 07:43 PM
gothspeed   To the OP, a 2056 or 2275 each have their virtues ...   May 18 2013, 08:11 PM
rhodyguy   1. dave hunt had nightmares trying to get even a m...   May 22 2013, 10:08 AM
- Lo-Fi Version Time is now: 9th June 2026 - 01:34 AM
