| 914itis |
May 1 2013, 04:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I sprayed a 2 stage paint for the first time. I primed with a 2 k primer cut with thinner, waited an hour spray the base coat, 3 coats then clear coat.
I am not sure If i miss some spots or if it is a reaction, for some reason, I can see the primer under the paint. It's hard to see but can be seen with enough lighting. It can be see in a few areas. What did I do wrong and how do I correct this ? |
| 914itis |
May 21 2013, 06:52 PM
Final product.
914itis 2 stage paint May 1 2013, 04:50 PM
bulitt Dont have a clue, but the experts will want to kno... May 1 2013, 05:16 PM
Andyrew How many coats of base did you use?
Depending on... May 1 2013, 05:28 PM
ThePaintedMan :agree:
I don't have near the experience as ... May 1 2013, 05:34 PM
914itis I sprayed 3 coats, the primer is grey and the pain... May 1 2013, 06:59 PM
ThePaintedMan Red is a thin pigment as well and sometimes requir... May 1 2013, 07:42 PM
PanelBilly I think you have an expensive guide coat at the po... May 1 2013, 08:10 PM
McMark What line of PPG? If it's OMNI (the cheap stu... May 1 2013, 09:23 PM
914itis Yes , Omni. I asked for good stuff and that's ... May 1 2013, 09:25 PM
McMark WOW. :blink:
Don't ever go back to that pain... May 1 2013, 09:30 PM
ThePaintedMan
WOW. :blink:
Don't ever go back to that pai... May 1 2013, 09:32 PM
a914622 Is it thin all over or just a door bottom or somet... May 1 2013, 10:23 PM
914itis No, It is not all over.
I have 3 small spots.
un... May 1 2013, 10:41 PM
ThePaintedMan Ah, I know what you did then. You just simply miss... May 1 2013, 11:26 PM
914itis
Ah, I know what you did then. You just simply mis... May 1 2013, 11:36 PM
bulitt Paul- You want the Deltron Line from PPG, primer, ... May 2 2013, 05:02 AM
914itis I spoke to the clown at the paint shop . He told m... May 2 2013, 06:17 AM
timothy_nd28 I think a step was left out, the sealer coat after... May 2 2013, 07:04 AM
rick 918-S When I had my shop the DuPont rep would pull the s... May 2 2013, 07:11 AM
914itis
When I had my shop the DuPont rep would pull the ... May 2 2013, 07:25 AM
scotty b PM sent
Your paint supplier is an absolute idiot.... May 2 2013, 07:16 AM
Andyrew Paul,
At this point I think your best bet is to ... May 2 2013, 07:35 AM
scotty b
Paul,
At this point I think your best bet is to... May 2 2013, 07:40 AM
Andyrew Makes sense. I had a fear of solvents escaping whi... May 2 2013, 07:54 AM
914itis I am shopping for new paint.
1- whats a good bra... May 2 2013, 09:00 AM
a914622 If the spots are small enough or there is a small ... May 2 2013, 09:27 AM
914itis Any one heard of LUSID technology paint? May 2 2013, 10:24 AM
bulitt You need to call Scotty. And here is my guess why... May 2 2013, 11:32 AM
scotty b First off, when you go in with a code for these ca... May 2 2013, 12:36 PM
ThePaintedMan
First off, when you go in with a code for these c... May 2 2013, 12:47 PM
bulitt
First off, when you go in with a code for these c... May 2 2013, 02:29 PM
scotty b Shopline is only available through the " plat... May 2 2013, 06:52 PM
scotty b double dirka May 2 2013, 06:53 PM
914itis
double dirka
:confused: May 2 2013, 07:05 PM
scotty b
double dirka
:confused:
interweb connection h... May 2 2013, 07:38 PM
914itis Update
I manage to sand down to the paint and rep... May 4 2013, 07:09 PM
914itis More May 4 2013, 07:11 PM
bulitt Yup. the clear should come out fine. Be careful s... May 4 2013, 07:15 PM
Andyrew Can you put a florescent above and take another sh... May 4 2013, 07:48 PM
914itis Yes it is the clear only. May 4 2013, 07:51 PM
scotty b that Is orange peel. Wet sand it. If you want to b... May 4 2013, 07:56 PM
Andyrew
that Is orange peel. Wet sand it. If you want to ... May 5 2013, 11:38 AM
914itis Thanks all, will start wet sanding in 24 hours and... May 4 2013, 08:15 PM
914itis Scotty, What color code was this? you posted this ... May 5 2013, 11:02 AM
scotty b
Scotty, What color code was this? you posted this... May 5 2013, 02:40 PM
914itis
Scotty, What color code was this? you posted thi... May 5 2013, 08:06 PM
914itis Another 4 Hours of wet sand today. that makes it a... May 6 2013, 08:52 PM
scotty b 2
DO NOT buff those spots before doing this. now... May 7 2013, 06:00 AM
914itis Thanks, is there a time frame to buff after wetsan... May 7 2013, 06:05 AM
scotty b
Thanks, is there a time frame to buff after wetsa... May 7 2013, 11:51 AM
914itis Update
After gathering everyone's profession... May 14 2013, 09:34 AM
scotty b :beer2: May 14 2013, 06:13 PM
rick 918-S Glad it worked out for you. May 14 2013, 06:17 PM
ThePaintedMan Way to go Paul! You did it right by repainting... May 21 2013, 07:04 PM
914itis Thanks, a bit of patience, and yes I learned a lot... May 21 2013, 07:20 PM
914itis iPhone and glare from the hot sun today.
Scotty w... May 21 2013, 07:33 PM
76-914 That really looks good Paul. :poke: Is your son ... May 21 2013, 07:54 PM
914itis
That really looks good Paul. :poke: Is your son... May 21 2013, 08:43 PM
Andyrew Looks great! May 21 2013, 10:16 PM
saigon71 Paul:
Must have been frustrating as hell going th... May 22 2013, 06:27 AM
jimkelly good paint video - epoxy primer, 2k primer, base c... Sep 10 2013, 09:10 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:20 PM |
