> No power to fuel pump, seems to be a common problem around here
warrenoliver
post May 24 2013, 10:04 PM
Car stalled on me this morning. When I tried to restart, the fuel pump would not turn on so no luck with the start. Towed it home and checked it out. It is a 73 2.0 with FI.
The pump runs when I jumper directly to the battery. I have continuity from pump connector to the #13 pin on the relay board. If I jumper from the fuse to the #13 pin, the pump comes on. The fuse is good.
I have replaced the main power relay and the fuel pump relay with known good ones. With the ignition on, when I remove and reseat the main power relay, I can feel the relay click but I do not hear the injectors click nor do I hear the fuel pump start (I got this test from Dr. 914's Tech Tips).
On the fuel pump relay socket, I have power at the 30 pin and also the 85 pin. When I jumper to the 87, it does not turn on the fuel pump.
I don't know if it is related, but I have the same problem with the heater blower relay also. I jumpered 30 to 87 and I do not have power. I am not sure but I think the car died when I had the heater blower running.
I'm stumped. What do I check next?
post May 25 2013, 08:09 AM
. Here ya go http://members.rennlist.com/pbanders/FPChecklist_frame.htm
warrenoliver
post May 25 2013, 09:43 AM
Thanks for the Anders troubleshooting tips. When i follow his guide, it instructs me to "remove the ECU from bracket and remove wiring harness plug" - I don't see a plug, the wiring harness goes directly into the ECU. Do I have to open the case of the ECU?
QUOTE(76-914 @ May 25 2013, 09:09 AM) *
Bob L.
post May 25 2013, 10:26 AM
QUOTE(warrenoliver @ May 25 2013, 10:43 AM) *
There's a clamp that holds the harness at the corner of the ECU where the wires go in.
Loosen it and slide the plastic cover off.
You will then be able to grab the plastic handle and unplug the harness from the ECU. Carefully pull it straight out.
warrenoliver
post May 25 2013, 12:17 PM
OMG, thanks Dave for the pictures. Without those, if i had opened the ECU and seen that mess, i would have closed it up! I will have to get after it this afternoon.
Thanks again.
warrenoliver   No power to fuel pump   May 24 2013, 10:04 PM
Tom   Jumpering pin 87 of the fuel pump relay is the sam...   May 25 2013, 03:46 AM
warrenoliver   Tom, When I jumper from the fuse to 87 of the fue...   May 25 2013, 07:17 AM
warrenoliver   I tested the heater fan circuit also. The fan run...   May 25 2013, 08:00 AM
warrenoliver   I spread the pins on the relays and cleaned the co...   May 25 2013, 08:37 AM
Dave_Darling   Both the heater fan blower and the fuel pump relay...   May 25 2013, 08:45 AM
warrenoliver   Thanks Dave, The relays are good. When i have the...   May 25 2013, 09:37 AM
Dave_Darling   When i have the power supply relay in, and the ke...   May 26 2013, 11:26 AM
Jon H.   Do you still hear the clicking coming from the TPS...   May 25 2013, 04:20 AM
Cap'n Krusty   Install the 2 headlight motor relays in the FI con...   May 25 2013, 07:36 AM
warrenoliver   I tried that previously but I just tried it again ...   May 25 2013, 09:23 AM
76-914   . Here ya go http://members.rennlist.com/...   May 25 2013, 08:09 AM
warrenoliver   Thanks for the Anders troubleshooting tips. When ...   May 25 2013, 09:43 AM
Bob L.   Thanks for the Anders troubleshooting tips. When...   May 25 2013, 10:26 AM
warrenoliver   OMG, thanks Dave for the pictures. Without those,...   May 25 2013, 12:17 PM
Bob L.   OMG, thanks Dave for the pictures. Without those...   May 25 2013, 12:50 PM
warrenoliver   Oops, sorry! Thanks Bob.   May 25 2013, 02:52 PM
Tom   Warren, Sorry to not answer back sooner. I have...   May 25 2013, 03:39 PM
warrenoliver   Tom, I think you may be right but I just don...   May 25 2013, 04:42 PM
Tom   Warren, From what you have said, it doesn't...   May 25 2013, 04:59 PM
warrenoliver   Tom, I unplugged the AAR and it didn't help. ...   May 25 2013, 07:00 PM
Jon H.   Don't forget, he is also not hearing the injec...   May 25 2013, 05:22 PM
warrenoliver   I can hear clicking when I reseat the relays but I...   May 25 2013, 06:42 PM
Jon H.   I can hear clicking when I reseat the relays but ...   May 25 2013, 07:02 PM
warrenoliver   Yes, when I jumper from the fuse to the 86 socket ...   May 25 2013, 07:21 PM
Jon H.   Yes, when I jumper from the fuse to the 86 socket...   May 25 2013, 07:52 PM
warrenoliver   Thanks for all your help guys. Anyone know where I...   May 25 2013, 07:55 PM
Jon H.   Thanks for all your help guys. Anyone know where ...   May 26 2013, 05:55 AM
Tom   Warren, That could very well be the problem. ...   May 25 2013, 07:47 PM
Tom   Warren, I agree, you are getting very close to ...   May 26 2013, 12:24 PM
warrenoliver   Some great ideas there Tom. I really appreciate e...   May 26 2013, 03:31 PM
jk76.914   Warren, I agree, you are getting very close to...   May 17 2015, 05:23 PM
Tom   Warren, The #30 pin for the two relays are from...   May 26 2013, 05:03 PM
warrenoliver   I must be missing something then. When i look at ...   May 27 2013, 09:05 AM
Tom   Warren, Take another look. Follow the lines ...   May 27 2013, 09:45 AM
warrenoliver   Tom, Aha! I think you may be on to it. Even...   May 27 2013, 12:22 PM
warrenoliver   DAMN!!!!!! This thing is...   May 27 2013, 03:36 PM
warrenoliver   I think I have finally tracked it down. With the ...   May 27 2013, 07:28 PM
Jon H.   I find these electrical Gremlins to be the most fr...   May 28 2013, 04:17 AM
Tom   Warren, Very happy I could help. Glad things ...   May 28 2013, 10:56 AM
revhi109   I am also having issues with my fuel pump not comi...   Mar 30 2015, 10:12 AM
warrenoliver   I am also having issues with my fuel pump not com...   Apr 1 2015, 07:20 PM
flylarry   If the relay works and a jumper between the fuse a...   May 17 2015, 08:15 PM
- Lo-Fi Version Time is now: 9th June 2026 - 03:49 AM
