| warrenoliver |
May 24 2013, 10:04 PM
Member ![]() ![]() Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
Car stalled on me this morning. When I tried to restart, the fuel pump would not turn on so no luck with the start. Towed it home and checked it out. It is a 73 2.0 with FI.
The pump runs when I jumper directly to the battery. I have continuity from pump connector to the #13 pin on the relay board. If I jumper from the fuse to the #13 pin, the pump comes on. The fuse is good. I have replaced the main power relay and the fuel pump relay with known good ones. With the ignition on, when I remove and reseat the main power relay, I can feel the relay click but I do not hear the injectors click nor do I hear the fuel pump start (I got this test from Dr. 914's Tech Tips). On the fuel pump relay socket, I have power at the 30 pin and also the 85 pin. When I jumper to the 87, it does not turn on the fuel pump. I don't know if it is related, but I have the same problem with the heater blower relay also. I jumpered 30 to 87 and I do not have power. I am not sure but I think the car died when I had the heater blower running. I'm stumped. What do I check next? |
| Jon H. |
May 25 2013, 05:22 PM
Member ![]() ![]() Group: Members Posts: 242 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
Don't forget, he is also not hearing the injectors click. If both the fuel pump and the injectors are affected then there is an issue with either the ECU or the power supply to the ECU. Do you hear the clicking from the TPS when you move the throttle by hand when the key is in the run position?
Jon |
| warrenoliver |
May 25 2013, 06:42 PM
I can hear clicking when I reseat the relays but I am hard of hearing and wear hearing aids so I am not always able to hear things. The clicking I hear sounds like it is onl coming from the power supply relay.
When I move the throttle by hand, I can hear it clicking when the key is on. |
| Jon H. |
May 25 2013, 07:02 PM
I can hear clicking when I reseat the relays but I am hard of hearing and wear hearing aids so I am not always able to hear things. The clicking I hear sounds like it is onl coming from the power supply relay. When I move the throttle by hand, I can hear it clicking when the key is on. That's good then, what about the injectors, are they clicking? If they are and if you jump the power to the fuel pump and you are still getting spark then you should be able to start the car. Jon |
| warrenoliver |
May 25 2013, 07:21 PM
Yes, when I jumper from the fuse to the 86 socket on the fuel pump relay, it starts and runs just fine. When i remove the jumper and replace the relay, no fuel pump - although one of the times I removed the jumper and replaced the relay, the pump came on and the car started. Several subsequent tries and no luck. I am leaning toward a relay board problem like an intermittent short or break in the 86 trace.
| Jon H. |
May 25 2013, 07:52 PM
Yes, when I jumper from the fuse to the 86 socket on the fuel pump relay, it starts and runs just fine. When i remove the jumper and replace the relay, no fuel pump - although one of the times I removed the jumper and replaced the relay, the pump came on and the car started. Several subsequent tries and no luck. I am leaning toward a relay board problem like an intermittent short or break in the 86 trace. Then it could be a hairline break in one of the traces on the board. Jon |
| warrenoliver |
May 25 2013, 07:55 PM
Thanks for all your help guys. Anyone know where I can get a good relay board?
I will try the classifieds |
| Jon H. |
May 26 2013, 05:55 AM
Thanks for all your help guys. Anyone know where I can get a good relay board? I will try the classifieds You can pull the board off and test for continuity first. If there is broken trace you can heat up the black stuff and scrap it off and solder the broken trace. |
warrenoliver No power to fuel pump May 24 2013, 10:04 PM
Tom Jumpering pin 87 of the fuel pump relay is the sam... May 25 2013, 03:46 AM
warrenoliver Tom,
When I jumper from the fuse to 87 of the fue... May 25 2013, 07:17 AM
warrenoliver I tested the heater fan circuit also. The fan run... May 25 2013, 08:00 AM
warrenoliver I spread the pins on the relays and cleaned the co... May 25 2013, 08:37 AM
Dave_Darling Both the heater fan blower and the fuel pump relay... May 25 2013, 08:45 AM
warrenoliver Thanks Dave,
The relays are good. When i have the... May 25 2013, 09:37 AM
Dave_Darling
When i have the power supply relay in, and the ke... May 26 2013, 11:26 AM
Jon H. Do you still hear the clicking coming from the TPS... May 25 2013, 04:20 AM
Cap'n Krusty Install the 2 headlight motor relays in the FI con... May 25 2013, 07:36 AM
warrenoliver I tried that previously but I just tried it again ... May 25 2013, 09:23 AM
76-914 . Here ya go http://members.rennlist.com/... May 25 2013, 08:09 AM
warrenoliver Thanks for the Anders troubleshooting tips. When ... May 25 2013, 09:43 AM
Bob L.
Thanks for the Anders troubleshooting tips. When... May 25 2013, 10:26 AM
warrenoliver OMG, thanks Dave for the pictures. Without those,... May 25 2013, 12:17 PM
Bob L.
OMG, thanks Dave for the pictures. Without those... May 25 2013, 12:50 PM
warrenoliver Oops, sorry! Thanks Bob.
May 25 2013, 02:52 PM
Tom Warren,
Sorry to not answer back sooner. I have... May 25 2013, 03:39 PM
warrenoliver Tom,
I think you may be right but I just don... May 25 2013, 04:42 PM
Tom Warren,
From what you have said, it doesn't... May 25 2013, 04:59 PM
warrenoliver Tom,
I unplugged the AAR and it didn't help.
... May 25 2013, 07:00 PM
Tom Warren,
That could very well be the problem. ... May 25 2013, 07:47 PM
Tom Warren,
I agree, you are getting very close to ... May 26 2013, 12:24 PM
warrenoliver Some great ideas there Tom. I really appreciate e... May 26 2013, 03:31 PM
jk76.914
Warren,
I agree, you are getting very close to... May 17 2015, 05:23 PM
Tom Warren,
The #30 pin for the two relays are from... May 26 2013, 05:03 PM
warrenoliver I must be missing something then. When i look at ... May 27 2013, 09:05 AM
Tom Warren,
Take another look. Follow the lines ... May 27 2013, 09:45 AM
warrenoliver Tom,
Aha! I think you may be on to it. Even... May 27 2013, 12:22 PM
warrenoliver DAMN!!!!!! This thing is... May 27 2013, 03:36 PM
warrenoliver I think I have finally tracked it down. With the ... May 27 2013, 07:28 PM
Jon H. I find these electrical Gremlins to be the most fr... May 28 2013, 04:17 AM
Tom Warren,
Very happy I could help. Glad things ... May 28 2013, 10:56 AM
revhi109 I am also having issues with my fuel pump not comi... Mar 30 2015, 10:12 AM
warrenoliver
I am also having issues with my fuel pump not com... Apr 1 2015, 07:20 PM
flylarry If the relay works and a jumper between the fuse a... May 17 2015, 08:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:30 AM |
