choice of welding machines |
CTDan914 |
May 30 2013, 05:19 AM
Newbie Group: Members Posts: 46 Joined: 23-April 12 Member No.: 14,415 Region Association: North East States |
I'm no sure if this is the right spot for this or not but here it is.
I see a lot of you guys do your own welding on your cars. I plan on getting a welder soon and the electrician running the 220 wants to know which plug to install. HUH! The machine I'm thinking of will be either a Miller or Lincoln Electric. Someone once told me to stick to a known name brand because it's easier to get serviced locally if needed. OK, but what size welder do I need that's the question. Can you guys help me with this? I want something that can be used on body work up to maybe 1/4 to 5/16" think tubing etc. A friend of mine said mig is the way to go. What would you be using? Dan |
VaccaRabite |
May 30 2013, 08:02 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I used my Miller 135 (15v) to weld 1/4 inch (but did it using non-mig wire, and did not do much of it).
If you will be welding a lot of 1/4 inch wall tube, I'd get the 220. But for 914 sized metal the 115 volt machine is fine and the 220 is overkill. Zach |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:09 AM |
