1st auto-x next weekend, Next AX September 8th- only 7 points out of 3rd place with 3 events left! |
scott_in_nh |
Apr 13 2013, 05:56 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
74, stock 2.0, stock front swaybar - no rear bar, stock front inserts, may mount an older set of adjustable Koni's I already have on the back, either way 100 lb springs, 195/65 Eagle GT's.
Looking to have fun, not too worried about much else, but I have a few basic setup questions: I'm going to chalk the tires, but what pressure should I start at? Full tank, half tank or empty tank? Spare tire in or out? The konis need to be adjusted out of the car - soft, medium or firm (keep in mind I will have to live with it on NH streets too)? Should I overfill the oil a bit? If so how much? What am I missing? Thanks, Scott |
r_towle |
Jun 4 2013, 01:12 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I would suggest rear springs are the next upgrade...
Leave the bar...to hard to replace and not as worthwhile as rear springs. You can also make (or find) other links for the horizontal piece.. If you get that drop link closer to the main bar, you will feel the results. Me, I found a soft front and a stiff rear works best with the low power of the stock motor. You need to get the car setup so you can fish tail it with the gas pedal... That is motor, or suspension. If you are low budget....think about rubber spacers in the rear springs. Cheap to make, and wire them in place. rich |
Woody |
Jun 4 2013, 02:19 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
I would suggest rear springs are the next upgrade... Leave the bar...to hard to replace and not as worthwhile as rear springs. You can also make (or find) other links for the horizontal piece.. If you get that drop link closer to the main bar, you will feel the results. Me, I found a soft front and a stiff rear works best with the low power of the stock motor. You need to get the car setup so you can fish tail it with the gas pedal... That is motor, or suspension. If you are low budget....think about rubber spacers in the rear springs. Cheap to make, and wire them in place. rich I agree that rear springs should be your next upgrade but come on Rich, spacers? (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/poke.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 08:18 PM |
