ride height vs. stock with 165 lbs. progressive springs?, I'm not looking to lower the car.... |
scott_in_nh |
Jun 5 2013, 11:52 AM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
So I would like to know what size spacers I need to keep the car at about the stock ride height.
Thanks |
Jeffs9146 |
Jun 5 2013, 01:24 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
160# springs
The spacers are 2" electrical conduit couplings cut at the center seam with a grinder! If you dicide you want it lower just grind off another 1/4" of the bottom of the coupler! I have done 4 sets starting at 1 1/2" and going to 3 1/2" depending on my springs and wheels! They fit over the Koni's perfect and when you tighten the coupling it clamps the coupling to the shock! |
scott_in_nh |
Jun 5 2013, 01:45 PM
160# springs The spacers are 2" electrical conduit couplings cut at the center seam with a grinder! If you dicide you want it lower just grind off another 1/4" of the bottom of the coupler! I have done 4 sets starting at 1 1/2" and going to 3 1/2" depending on my springs and wheels! They fit over the Koni's perfect and when you tighten the coupling it clamps the coupling to the shock! What is your front end set up (torsion and sway bar) and how do you like it (road and track if you do both)? |
Lo-Fi Version | Time is now: 12th June 2024 - 08:23 AM |
