casey944 |
Member ![]() ![]() Group: Members Posts: 139 Joined: 10-August 09 From: nova Member No.: 10,654 Region Association: MidAtlantic Region ![]() |
I dont recall ever having the hoses hooked up that come out of my late 72 1.7L head where you can feel venting exiting the car. Recently did a bunch of tune up work and went for the first real drive yesterday. Car is running well but both of the vents had quite a bit of oil come out and go all over the engine tin. Realize this was over a 30 mile highway drive... I pulled over, plugged in the one by cyl3(had a hose there) cleaned up the mess and then drove some more... Then I notice oil coming out of the other port on the drivers side of the engine by my carb manifold... However I dont see a hose over there to plug it in to...
Anyone have a diagram of how this is to work or a kit? I honestly dont feel either of these had ever been plugged in but since I recently changed the oil(and possibly overfilled a bit) that might have caused the excess oil above the engine... For once the bottom of my engine doesnt leak but the top does! Thanks in advance. Casey |
casey944 |
I am assuming it was just a little overfilled as I had never dealt with this before. I think i will likely create some sort of catch cant to port both sides into.
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
I am assuming it was just a little overfilled as I had never dealt with this before. I think i will likely create some sort of catch cant to port both sides into. I would think you'd need something as there would at least be oil vapor coming out of the ports in the heads and spewing oil vapor into your engine compartment and creating a mess there... |
Lo-Fi Version | Time is now: 1st August 2025 - 04:52 AM |
