Oil Pump |
Oil Pump |
newdeal2 |
Jul 5 2004, 09:00 PM
Unregistered |
On a stock rebuild is the stock pump good to re use or do you all recomend upgrading? I know Jake does a retro to a type 1 pump.
Anyone make a kit? Peter 74 2 Liter |
Jake Raby |
Jul 8 2004, 05:53 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
No gaskets... Loctite 518 between the pump and case...
blueprint the pump and use 800 grit sandpaper to get .0015 clearance between the cover and pump gears... Then use no gasket there either.. If you use a gasket, the TI gasket works and coat it with "copper coat" in a spray can... |
Lo-Fi Version | Time is now: 7th June 2024 - 07:54 AM |
