thelogo. charging your dead optima, cheap fix procedure |
rhodyguy |
Jun 7 2013, 07:43 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
not wanting to buy a new battery to replace my almost fully discharged (.4 v) one i found this online. take a KNOWN fully charged bat and connect the dead one in parallel with a set of jumper cables, +to+ and -to-. connect the charger to the dead bat and charge for 1 hour. then remove the jumpers and charge the previously dead one as normal. it worked GREAT!! not wanting to overcharge by letting the trickle charger run all night i stopped last evening and i checked the v this am. lost .1 volts. on a recharge mode this am for a full charge. if successful its money in the bank.
worn |
Jun 7 2013, 09:12 AM
can't remember Group: Members Posts: 3,165 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
not wanting to buy a new battery to replace my almost fully discharged (.4 v) one i found this online. take a KNOWN fully charged bat and connect the dead one in parallel with a set of jumper cables, +to+ and -to-. connect the charger to the dead bat and charge for 1 hour. then remove the jumpers and charge the previously dead one as normal. it worked GREAT!! not wanting to overcharge by letting the trickle charger run all night i stopped last evening and i checked the v this am. lost .1 volts. on a recharge mode this am for a full charge. if successful its money in the bank. Isn't that the Optima suggested charging recovery mode? I have a 3-year old red top that is sort of funky about charging but won't die. But the battery in the 911 is a 10-year old die hard, so maybe the money isn't the thing. |
Lo-Fi Version | Time is now: 11th June 2024 - 07:18 PM |
