| Highland |
May 26 2013, 09:19 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 559 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I'm attempting to rebuild a 2.0 engine. Plan on using the original D-jet and 94mm piston and cylinders, stock rods and crank too. It's time to choose a cam and it seems like the best option is Raby's 9590 kit. From what I can tell the "Super Kit" includes everything except the set-up adjusting pushrod. I already have a set of modified 1.7 rockers for the swivel feet adjusters.
I just want to get some opinions on Raby's 9590 kit and if I'm missing something here as far as new parts. From what I can tell the kit includes everything I need for the valve train and this cam profile will work well with my stock set-up. |
| Highland |
Jun 7 2013, 08:35 AM
Does anyone know if the Raby 9590 Super Kit includes the adjusting pushrod or do I have to purchase that separately?
| worn |
Jun 7 2013, 09:46 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,571 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Does anyone know if the Raby 9590 Super Kit includes the adjusting pushrod or do I have to purchase that separately? You can do what I did. Saw a chunk out of an old push rod, tap it, cut the head off a threaded object or use all-thread, and add some lock nuts. I used 1/4 by 20. In the end they turned out pretty close to stock. Also, those aluminum push rods are thick! |
| JFJ914 |
Jun 7 2013, 05:41 PM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States
Does anyone know if the Raby 9590 Super Kit includes the adjusting pushrod or do I have to purchase that separately? You can do what I did. Saw a chunk out of an old push rod, tap it, cut the head off a threaded object or use all-thread, and add some lock nuts. I used 1/4 by 20. In the end they turned out pretty close to stock. Also, those aluminum push rods are thick! Nice, BUT the radius of the steel pushrods is different. Your lengths with the aluminum push rod will be different than the steel push rod. |
Highland Cam Kit Question May 26 2013, 09:19 AM
The Cabinetmaker I have his 9550. Very satisfied. What's the di... May 26 2013, 11:44 AM
Highland According to the Type IV web site the 9590 is a re... May 26 2013, 03:21 PM
Mblizzard Well as the old saying goes "The only thing t... May 26 2013, 03:31 PM
r_towle I dont have an iphone, but they seem to take the s... May 26 2013, 04:02 PM
draganc Jake's stuff is top notch, however, since you ... May 26 2013, 07:04 PM
Jake Raby The 9550 is no more, hasn't been for over a ye... May 26 2013, 07:35 PM
smveril I am going through the same process of rebuilding ... May 27 2013, 05:51 AM
hedfurst I used the 9550 with some 94mm Mahle flat-tops and... May 27 2013, 06:01 AM
John Jentz
Does anyone know if the Raby 9590 Super Kit inclu... Jun 7 2013, 08:44 AM
mgphoto Bought the 9550 super kit a year ago, worked out g... Jun 7 2013, 06:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 12:30 PM |
