| Mike Bellis |
Jun 7 2013, 10:17 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I can here my 944 CV's clicking due to the extreem angle. The Boxster/Audi transaxle flanges sit forward of the trailing arm position. I think I need to swap to a 930 CV but they won't fit in the trailing arm.
Anyone ever built or bought a spacer/adapter to go from 911 bolt pattern to 930 bolt pattern? |
| strawman |
Jun 8 2013, 12:26 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 892 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California
I've got a pair of 930 CVs you can have. You gonna be in SLO anytime soon?
| Mike Bellis |
Jun 8 2013, 12:36 AM
kg6dxn Anyone know of a 911 to 930 CV adapter Jun 7 2013, 10:17 AM
okieflyr I'd be curious as to what angles your working ... Jun 7 2013, 11:29 AM
pcar916 The 930's are 108mm right? I ran them for year... Jun 7 2013, 04:44 PM
strawman
I've got a pair of 930 CVs you can have. You... Jun 9 2013, 01:07 PM
kg6dxn
[quote name='kg6dxn' post='1876681' date='Jun 7 2... Jun 9 2013, 02:23 PM
kg6dxn I'm looking for something like this... It is a... Jun 8 2013, 08:00 AM
Krieger FWIW some early 911s (maybe 69?) used a 108mm cv j... Jun 8 2013, 08:15 AM
kg6dxn
FWIW some early 911s (maybe 69?) used a 108mm cv ... Jun 8 2013, 08:29 AM
pcar916 They fit. You just have to use the a 930 stub-axle... Jun 8 2013, 09:17 AM
kg6dxn
They fit. You just have to use the a 930 stub-axl... Jun 8 2013, 11:17 AM
pcar916 That looks like the animal. The splines match earl... Jun 8 2013, 12:34 PM
TurboWalt Mike,
Check with Scott at advancedautomotion 720-... Jun 8 2013, 07:05 PM
PRS914-6 The 108's will fit fine, I am using them in a ... Jun 9 2013, 07:28 PM
kg6dxn
The 108's will fit fine, I am using them in a... Jun 9 2013, 07:43 PM
PRS914-6
Who sells a 5mm spacer?
I think I have an ext... Jun 9 2013, 10:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 01:34 PM |
