> Help a 914 v8 newbie: shifter keeps loosing 4th and 5th :/
EthanBlack
post Jun 7 2013, 06:11 PM
Greetings ladies and gents!
Just a little bit about myself. Bought my first v8 car (283/rod Simpson car) right out of high school and fell in love with these unique cars. Had to sell it for school 6 months later but never lost love for them. Fast forward 8 years later and I bought a GM v6 (4.3) swapped car to try to re-live some of that previous magic. Figured car was too slow so I had a corvette shop build me a full roller 350 with a decently bumpy cam. Car gets squirly in 4th gear at full tilt and suffice to say the magic is back. But there in lies the problem as 4th and 5th are all but impossible to shift to while driving.
I can adjust the shifter while not in motion to get 4th and 5th. However once I start driving around, 4th disappears entirely and 5th can sometimes be found if I drive slowly. I've tried to adjust it multiple times and its driving me crazy!
I re-used the GM v6 engine mount bar which looks like it set the drive train back a few inches farther then the usual conversion kits. As a point of reference, I couldn't use renegades tranny mounts on their own and had to extend them another 2 inches using thick gauge metal and another pair of bolts. I'm thinking that the tranny mounts get "loose" as a load is placed in the system making shifting even more awkward.
I'm willing to pay for shop help but can't find anyone local in Southern California who would take on a v8 car. Just out of ideas and pulling hair, appreciate any help!
Cheers,
Ethan
Mike Bellis
post Jun 8 2013, 10:17 PM
Resident Electrician
Look at the rear mounts on mine. The "brick" colored piece is a relocation bracket. It moves the tranny rearward 1.25". The factory rubber mount (that you have) gets removed and replaced with the solid bar stock of the semi solid mount. The poly block is mounted between the relocating bracket and the bar stock.
You have a piece of pipe for a lowering spacer. This should not be there...
Although not a good pic, here you can see part of the front mount. It is straight across with a round end that bolts into the stock location. Again the factory mount is removed and replaced with a solid bracket of steel.
EthanBlack   Help a 914 v8 newbie: shifter keeps loosing 4th and 5th :/   Jun 7 2013, 06:11 PM
Steve   What year is the car? 1973 and newer have a side ...   Jun 7 2013, 06:27 PM
SirAndy   :wttc: Show us some pics of the shift linkage un...   Jun 7 2013, 06:30 PM
Steve   Thanks Andy!! I knew i forgot something.....   Jun 7 2013, 07:49 PM
messix   :ttiwwp:   Jun 7 2013, 08:00 PM
rick 918-S   Contact Sean Molloy at San Diego Autosport. http:/...   Jun 7 2013, 08:09 PM
JRust   Check the bar itself where it goes though your eng...   Jun 7 2013, 08:53 PM
messix   Check the bar itself where it goes though your en...   Jun 7 2013, 09:07 PM
JRust   Check the bar itself where it goes though your e...   Jun 7 2013, 09:30 PM
EthanBlack   Thank you for the welcome gents, - Steve: Car is ...   Jun 8 2013, 11:30 AM
messix   i'm thinking that the tranny mount extensions ...   Jun 8 2013, 12:17 PM
EthanBlack   messix: I think your right, it's definitely wi...   Jun 8 2013, 03:08 PM
SirAndy   http://www.914world.com/bbs2/uploads_offsite/i41.t...   Jun 8 2013, 04:31 PM
Steve   You can get 911 motor mounts pretty cheap from pel...   Jun 8 2013, 05:12 PM
EthanBlack   You can get 911 motor mounts pretty cheap from pe...   Jun 8 2013, 06:54 PM
kg6dxn   That looks like a homemade install. The renegade k...   Jun 8 2013, 07:44 PM
EthanBlack   I purchased the dark colored (not the brick colore...   Jun 8 2013, 08:49 PM
kg6dxn   Look at the rear mounts on mine. The "brick...   Jun 8 2013, 10:17 PM
Dr Evil   Do you have a metal piece under the bolt that is g...   Jun 9 2013, 09:07 AM
EthanBlack   kg6dxn: Thank you for the photos and clarification...   Jun 9 2013, 02:18 PM
- Lo-Fi Version Time is now: 16th April 2026 - 01:46 AM
