> Anyone know of a 911 to 930 CV adapter, or adapting spacer for 914 trailing arm?
Mike Bellis
post Jun 7 2013, 10:17 AM
Resident Electrician
I can here my 944 CV's clicking due to the extreem angle. The Boxster/Audi transaxle flanges sit forward of the trailing arm position. I think I need to swap to a 930 CV but they won't fit in the trailing arm.
Anyone ever built or bought a spacer/adapter to go from 911 bolt pattern to 930 bolt pattern?
PRS914-6
post Jun 9 2013, 07:28 PM
Excellence Magazine Project 914 3.6
Group: Retired Members
The 108's will fit fine, I am using them in a stock arm.
They will have four 10mm bolts with two roll pins
You can buy both tranny and drive flange in this pattern and the Sway-Away axles are an excellent upgrade that simplifies installation without adapters.
If you go this route don't buy the early drive flanges but instead get the later 911 hub-centric flanges. (requires 5mm bearing spacer)
This is all assuming you are going to go 5 lug.....
- Lo-Fi Version Time is now: 14th November 2026 - 01:34 PM
