| Mike Bellis |
Jun 7 2013, 10:17 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I can here my 944 CV's clicking due to the extreem angle. The Boxster/Audi transaxle flanges sit forward of the trailing arm position. I think I need to swap to a 930 CV but they won't fit in the trailing arm.
Anyone ever built or bought a spacer/adapter to go from 911 bolt pattern to 930 bolt pattern? |
| PRS914-6 |
Jun 9 2013, 07:28 PM
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
The 108's will fit fine, I am using them in a stock arm.
They will have four 10mm bolts with two roll pins You can buy both tranny and drive flange in this pattern and the Sway-Away axles are an excellent upgrade that simplifies installation without adapters. If you go this route don't buy the early drive flanges but instead get the later 911 hub-centric flanges. (requires 5mm bearing spacer) This is all assuming you are going to go 5 lug..... ![]() |
| Mike Bellis |
Jun 9 2013, 07:43 PM
The 108's will fit fine, I am using them in a stock arm. They will have four 10mm bolts with two roll pins You can buy both tranny and drive flange in this pattern and the Sway-Away axles are an excellent upgrade that simplifies installation without adapters. If you go this route don't buy the early drive flanges but instead get the later 911 hub-centric flanges. (requires 5mm bearing spacer) This is all assuming you are going to go 5 lug..... Very cool! I am running an Audi tranny so I have to have adapters there. I already have a 5 lug with 930 calipers and brakes. Looks like I need stub axles. I found a place that sells the adapter I need. Looks like it will all come together... Who sells a 5mm spacer? |
| PRS914-6 |
Jun 9 2013, 10:56 PM
kg6dxn Anyone know of a 911 to 930 CV adapter Jun 7 2013, 10:17 AM
okieflyr I'd be curious as to what angles your working ... Jun 7 2013, 11:29 AM
pcar916 The 930's are 108mm right? I ran them for year... Jun 7 2013, 04:44 PM
strawman I've got a pair of 930 CVs you can have. You g... Jun 8 2013, 12:26 AM
kg6dxn
I've got a pair of 930 CVs you can have. You ... Jun 8 2013, 12:36 AM
strawman
I've got a pair of 930 CVs you can have. You... Jun 9 2013, 01:07 PM
kg6dxn
[quote name='kg6dxn' post='1876681' date='Jun 7 2... Jun 9 2013, 02:23 PM
kg6dxn I'm looking for something like this... It is a... Jun 8 2013, 08:00 AM
Krieger FWIW some early 911s (maybe 69?) used a 108mm cv j... Jun 8 2013, 08:15 AM
kg6dxn
FWIW some early 911s (maybe 69?) used a 108mm cv ... Jun 8 2013, 08:29 AM
pcar916 They fit. You just have to use the a 930 stub-axle... Jun 8 2013, 09:17 AM
kg6dxn
They fit. You just have to use the a 930 stub-axl... Jun 8 2013, 11:17 AM
pcar916 That looks like the animal. The splines match earl... Jun 8 2013, 12:34 PM
TurboWalt Mike,
Check with Scott at advancedautomotion 720-... Jun 8 2013, 07:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 01:34 PM |
