> No sparks
914boy
post Jun 10 2013, 08:14 AM
I figured I should make a new thread.
Converting back to fuel injection
1.7 djet
We try to start the car, it cranks but does not start.
Timing and TDC are checked and spot on,
the coil will not spark.
Just to confirm. The thick black/ purple is on the positive (+) side of the coil and the small black and condenser on the negative (-)
With the ignition on, I get 12 volts at the + / black/ purple wire
with the ignition on, I have ground on the negative side of the coil,
when I crank, the negative side of the coil switches from ground to 12 volts positive
I replaced points and condenser and coil,Same issue.
914itis
post Jun 10 2013, 01:25 PM
It was tested with a test light. By 12 volts, I meant positive current.
1-
With the key on, I connect one the tip of test light to the positive side of the coil and the other end to ground, it (the test light) turns on.
2 - with the key on, the tip to the negative to side of the coil and the other side to ground, it (the test light) turns on, but went off when I crank.
Now if I connect the other end if the test light to ground while the tip is on the negative side of the coil and crank the light will turn on.
- Lo-Fi Version Time is now: 3rd November 2026 - 02:54 PM
