> Protective Cap for Oil Pressure Switch, Where do you get these?
74914LE
post Jun 10 2013, 07:44 PM
Anyone know where to get the Protective Cap for the Oil Pressure Switch? It is #64 in the picture below.
ThePaintedMan
post Jun 11 2013, 07:31 AM
Sorry, I forgot that I use the dual sender on a grease hose extension, so the hole in the tin is really large without some kind of grommet to seal it. If you're using the stock sender, then the Bus Boys solution is probably the better way to go.
Cap'n Krusty
post Jun 11 2013, 09:05 AM
Cap'n Krusty
QUOTE(ThePaintedMan @ Jun 11 2013, 06:31 AM) *
The original formed grommet should work just fine for the remote mounted sender. The hole in the center is pretty small. Because the hole is not a simple circle cut in a flat surface, a plain grommet may not work at all .............
The Cap'n
- Lo-Fi Version Time is now: 2nd September 2025 - 09:18 PM
