| stuttgart46 |
Jun 19 2013, 06:05 AM
Member ![]() ![]() Group: Members Posts: 305 Joined: 17-December 07 From: Santa Monica, CA Member No.: 8,474 Region Association: None |
I've got a '98 Boxster that is acting up. It had been running fine but lately when it gets to 180 degrees it just stalls out. Almost like a vapor lock from my first 914. I have replaced the fuel filter, Crank Position Sensor and cleaned the MAF but it is still doing the same thing. It's as if it hits a kill switch at exactly 180 degrees.
Any suggestions would be apprecited. |
| ThePaintedMan |
Jun 19 2013, 08:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
But, I have seen a faulty thermostat cause an Accord to stall/no restart. I believe it was a fail-safe mechanism to keep from overheating or continuing to run an overheated car. The temps on the dash said everything was okay, but thermostat was definitely bad and the computer was sensing either pressure in the system or a temperature differential before and after the thermostat, and shutting the car down. Not sure if Boxsters have a similar system. Do you know when it was changed last? It's at least a cheap place to start if you don't know it's condition. |
stuttgart46 OT: Boxster stalling out Jun 19 2013, 06:05 AM
Woody Any codes? Jun 19 2013, 06:17 AM
stuttgart46 The CEL is off because I disconnected the battery ... Jun 19 2013, 06:57 AM
stuttgart46 I wish you were a little closer Woody. There aren... Jun 19 2013, 06:58 AM
patssle
I wish you were a little closer Woody. There are... Jun 24 2013, 08:21 PM
Woody I'd just throw some Webers on it. :poke: You ... Jun 19 2013, 07:29 AM
Woody It looks like this, the black thingy.
Jun 19 2013, 07:32 AM
Philip W.
I've got a '98 Boxster that is acting up.... Jun 19 2013, 07:51 AM
stuttgart46 Thanks guys. I tried 986 Forum. It's like cr... Jun 19 2013, 08:12 AM
ThePaintedMan Is the fan coming on at all when this happens? Not... Jun 19 2013, 08:16 AM
Woody Never seen a faulty thermostat cause a Boxster to ... Jun 19 2013, 08:25 AM
stuttgart46 Me neither. Typically it would just run hot.
But ... Jun 19 2013, 08:41 AM
ThePaintedMan You can get a Bluetooth OBDII scanner on Ebay chea... Jun 19 2013, 08:57 AM
Cupomeat
You can get a Bluetooth OBDII scanner on Ebay che... Jun 19 2013, 11:41 AM
stuttgart46 Still waiting to scan but I cleaned the throttle b... Jun 20 2013, 05:56 AM
Woody
Still waiting to scan but I cleaned the throttle ... Jun 20 2013, 06:28 AM
ThePaintedMan Yeah.. I was going to suggest that. Have you been ... Jun 20 2013, 07:08 AM
stuttgart46 I do have a fuel pressure gauge that a buddy let m... Jun 20 2013, 07:36 AM
ThePaintedMan
I do have a fuel pressure gauge that a buddy let ... Jun 20 2013, 07:48 AM
stuttgart46 I did take the servo off while I was clean the thr... Jun 20 2013, 07:37 AM
stuttgart46 Thanks George. Just being able to bounce this stu... Jun 20 2013, 07:51 AM
ThePaintedMan
Thanks George. Just being able to bounce this st... Jun 20 2013, 07:55 AM
Woody The fuel test port has a brass cap that screws on.... Jun 20 2013, 10:41 AM
ThePaintedMan Woody, good call on the resistors. The Pelican art... Jun 20 2013, 08:14 PM
stuttgart46 Yesterday was the wife's b-day so no progress.... Jun 21 2013, 05:47 AM
ThePaintedMan Ah, that was the other thing I was wondering. Nice... Jun 21 2013, 06:18 AM
Woody Any updates? Jun 24 2013, 10:26 AM
BajaXJ92
Any upadates?
Fixed. Jun 24 2013, 07:18 PM
carr914
Ah, that was the other thing I was wondering. Nic... Jun 24 2013, 08:19 PM
ThePaintedMan
Ah, that was the other thing I was wondering. Ni... Jun 24 2013, 09:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:10 PM |
