> OT: Boxster stalling out
stuttgart46
post Jun 19 2013, 06:05 AM
I've got a '98 Boxster that is acting up. It had been running fine but lately when it gets to 180 degrees it just stalls out. Almost like a vapor lock from my first 914. I have replaced the fuel filter, Crank Position Sensor and cleaned the MAF but it is still doing the same thing. It's as if it hits a kill switch at exactly 180 degrees.
Any suggestions would be apprecited.
ThePaintedMan
post Jun 19 2013, 08:57 AM
You can get a Bluetooth OBDII scanner on Ebay cheap. Then buy an app like Torque which will allow you to scan the codes. Or rent/borrow the scanner from Autozone. Codes will at least point you in the right direction.
I did find this however:
http://forums.pelicanparts.com/boxster-cay...-when-warm.html
It might be coincidence that it happens at 180 degrees, but a failing fuel pump can act up more once it's gotten hot. However, I thought most of the time they just died.
stuttgart46   OT: Boxster stalling out   Jun 19 2013, 06:05 AM
Woody   Any codes?   Jun 19 2013, 06:17 AM
stuttgart46   The CEL is off because I disconnected the battery ...   Jun 19 2013, 06:57 AM
stuttgart46   I wish you were a little closer Woody. There aren...   Jun 19 2013, 06:58 AM
patssle   I wish you were a little closer Woody. There are...   Jun 24 2013, 08:21 PM
Woody   I'd just throw some Webers on it. :poke: You ...   Jun 19 2013, 07:29 AM
Woody   It looks like this, the black thingy.   Jun 19 2013, 07:32 AM
Philip W.   I've got a '98 Boxster that is acting up....   Jun 19 2013, 07:51 AM
stuttgart46   Thanks guys. I tried 986 Forum. It's like cr...   Jun 19 2013, 08:12 AM
ThePaintedMan   Is the fan coming on at all when this happens? Not...   Jun 19 2013, 08:16 AM
Woody   Never seen a faulty thermostat cause a Boxster to ...   Jun 19 2013, 08:25 AM
stuttgart46   Me neither. Typically it would just run hot. But ...   Jun 19 2013, 08:41 AM
ThePaintedMan   :agree: But, I have seen a faulty thermostat cau...   Jun 19 2013, 08:52 AM
ThePaintedMan   You can get a Bluetooth OBDII scanner on Ebay chea...   Jun 19 2013, 08:57 AM
Cupomeat   You can get a Bluetooth OBDII scanner on Ebay che...   Jun 19 2013, 11:41 AM
stuttgart46   Still waiting to scan but I cleaned the throttle b...   Jun 20 2013, 05:56 AM
Woody   Still waiting to scan but I cleaned the throttle ...   Jun 20 2013, 06:28 AM
ThePaintedMan   Yeah.. I was going to suggest that. Have you been ...   Jun 20 2013, 07:08 AM
stuttgart46   I do have a fuel pressure gauge that a buddy let m...   Jun 20 2013, 07:36 AM
ThePaintedMan   I do have a fuel pressure gauge that a buddy let ...   Jun 20 2013, 07:48 AM
stuttgart46   I did take the servo off while I was clean the thr...   Jun 20 2013, 07:37 AM
stuttgart46   Thanks George. Just being able to bounce this stu...   Jun 20 2013, 07:51 AM
ThePaintedMan   Thanks George. Just being able to bounce this st...   Jun 20 2013, 07:55 AM
Woody   The fuel test port has a brass cap that screws on....   Jun 20 2013, 10:41 AM
ThePaintedMan   Woody, good call on the resistors. The Pelican art...   Jun 20 2013, 08:14 PM
stuttgart46   Yesterday was the wife's b-day so no progress....   Jun 21 2013, 05:47 AM
ThePaintedMan   Ah, that was the other thing I was wondering. Nice...   Jun 21 2013, 06:18 AM
Woody   Any updates?   Jun 24 2013, 10:26 AM
BajaXJ92   Any upadates? Fixed.   Jun 24 2013, 07:18 PM
carr914   Ah, that was the other thing I was wondering. Nic...   Jun 24 2013, 08:19 PM
ThePaintedMan   Ah, that was the other thing I was wondering. Ni...   Jun 24 2013, 09:13 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:34 PM
