> OT: Boxster stalling out
stuttgart46
post Jun 19 2013, 06:05 AM
I've got a '98 Boxster that is acting up. It had been running fine but lately when it gets to 180 degrees it just stalls out. Almost like a vapor lock from my first 914. I have replaced the fuel filter, Crank Position Sensor and cleaned the MAF but it is still doing the same thing. It's as if it hits a kill switch at exactly 180 degrees.
Any suggestions would be apprecited.
ThePaintedMan
post Jun 19 2013, 08:57 AM
You can get a Bluetooth OBDII scanner on Ebay cheap. Then buy an app like Torque which will allow you to scan the codes. Or rent/borrow the scanner from Autozone. Codes will at least point you in the right direction.
I did find this however:
http://forums.pelicanparts.com/boxster-cay...-when-warm.html
It might be coincidence that it happens at 180 degrees, but a failing fuel pump can act up more once it's gotten hot. However, I thought most of the time they just died.
Cupomeat
post Jun 19 2013, 11:41 AM
missing my NY 914 in VA
QUOTE(ThePaintedMan @ Jun 19 2013, 10:57 AM) *
Good Find, and I know it has nothing to do with it, but my old 84.5 Scirocco used to have a stalling issue when hot and it turned out to be clogging of the transfer pump in the tank. Worked great when cold, then crappy as soon as it got to operating temp. Obviously, it is a different system but all engines need fuel.
stuttgart46   OT: Boxster stalling out   Jun 19 2013, 06:05 AM
Woody   Any codes?   Jun 19 2013, 06:17 AM
stuttgart46   The CEL is off because I disconnected the battery ...   Jun 19 2013, 06:57 AM
stuttgart46   I wish you were a little closer Woody. There aren...   Jun 19 2013, 06:58 AM
patssle   I wish you were a little closer Woody. There are...   Jun 24 2013, 08:21 PM
Woody   I'd just throw some Webers on it. :poke: You ...   Jun 19 2013, 07:29 AM
Woody   It looks like this, the black thingy.   Jun 19 2013, 07:32 AM
Philip W.   I've got a '98 Boxster that is acting up....   Jun 19 2013, 07:51 AM
stuttgart46   Thanks guys. I tried 986 Forum. It's like cr...   Jun 19 2013, 08:12 AM
ThePaintedMan   Is the fan coming on at all when this happens? Not...   Jun 19 2013, 08:16 AM
Woody   Never seen a faulty thermostat cause a Boxster to ...   Jun 19 2013, 08:25 AM
stuttgart46   Me neither. Typically it would just run hot. But ...   Jun 19 2013, 08:41 AM
ThePaintedMan   :agree: But, I have seen a faulty thermostat cau...   Jun 19 2013, 08:52 AM
ThePaintedMan   You can get a Bluetooth OBDII scanner on Ebay chea...   Jun 19 2013, 08:57 AM
Cupomeat   You can get a Bluetooth OBDII scanner on Ebay che...   Jun 19 2013, 11:41 AM
stuttgart46   Still waiting to scan but I cleaned the throttle b...   Jun 20 2013, 05:56 AM
Woody   Still waiting to scan but I cleaned the throttle ...   Jun 20 2013, 06:28 AM
ThePaintedMan   Yeah.. I was going to suggest that. Have you been ...   Jun 20 2013, 07:08 AM
stuttgart46   I do have a fuel pressure gauge that a buddy let m...   Jun 20 2013, 07:36 AM
ThePaintedMan   I do have a fuel pressure gauge that a buddy let ...   Jun 20 2013, 07:48 AM
stuttgart46   I did take the servo off while I was clean the thr...   Jun 20 2013, 07:37 AM
stuttgart46   Thanks George. Just being able to bounce this stu...   Jun 20 2013, 07:51 AM
ThePaintedMan   Thanks George. Just being able to bounce this st...   Jun 20 2013, 07:55 AM
Woody   The fuel test port has a brass cap that screws on....   Jun 20 2013, 10:41 AM
ThePaintedMan   Woody, good call on the resistors. The Pelican art...   Jun 20 2013, 08:14 PM
stuttgart46   Yesterday was the wife's b-day so no progress....   Jun 21 2013, 05:47 AM
ThePaintedMan   Ah, that was the other thing I was wondering. Nice...   Jun 21 2013, 06:18 AM
Woody   Any updates?   Jun 24 2013, 10:26 AM
BajaXJ92   Any upadates? Fixed.   Jun 24 2013, 07:18 PM
carr914   Ah, that was the other thing I was wondering. Nic...   Jun 24 2013, 08:19 PM
ThePaintedMan   Ah, that was the other thing I was wondering. Ni...   Jun 24 2013, 09:13 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:30 PM
