Fuchs 2L Center Caps, Glued In? |
turk22 |
Jun 25 2013, 02:42 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
I had new tires put on my car yesterday, the boys at the tire shop had a hell of a time getting my center caps off the wheels to balance the tires. They said it appeared the caps were glued in... I was assuming they were a press fit, but the PO may have done something to assure they wouldn't come off.
Anyone have any opinions, should they just be press fit, or was some adhesive typically used to assure they wouldn't come off? |
TheCabinetmaker |
Jun 25 2013, 02:53 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
They are press fit.
The tire monkeys usually beat them all to F***. I use a piece of pvc. One end is turned down on the outside to remove them from the inside of the wheel. The other end is turned on the inside to fit over the cap for installation. I guess you might use a dab of adhesive if they are loose. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:27 AM |
