> paint info needed, what is the best primer to use
freezing14
post Jul 12 2004, 11:51 AM
freezing14
i am finaly done fixing the swiss cheeze on the car , it is all gone, i will be soda blasting the car within a couple of days and i will be putting the primer on myself to be able to do the most of the body work myself and i have looked into the different primer and now i am confused?? (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) i will be using the omni line of paint from PPG and there is a couple of different primer--
the epoxy etch, but it contains chrome ( very toxic) so reject as i have a home made paint booth
the regular epoxy but apparently it is not sandable ( wtf it means)
then there is the high build 1K no epoxy ??
then the high build 2K epoxy
the car is strait and very little pitting on the outside i had to joint the quater panel half way and i did a couple of patch but they are but weld so very little bondo
what is the best price versus quality way to do??
I know i have to primer, putty, primer and then paint , which one should I use for which
thanks you very much for your help
newdeal2
post Jul 12 2004, 01:42 PM
Unregistered
I'm not questioning your knowledge of the subject but why would you apply "putty" over primers? You always get better adhesion over the metal...so I have been told by a pro.
I want to know before we go any further.
freezing14   paint info needed   Jul 12 2004, 11:51 AM
newdeal2   I will be priming my GT6 this week [it's down ...   Jul 12 2004, 11:58 AM
newdeal2   PS...be very carefull what you use to blast the ca...   Jul 12 2004, 12:02 PM
djm914-6   Ive read that epoxy primer is the best to use over...   Jul 12 2004, 12:20 PM
newdeal2   I'm not questioning your knowledge of the subj...   Jul 12 2004, 01:42 PM
brant   head over to: http://www.autobodystore.com/ and ...   Jul 12 2004, 01:48 PM
freezing14   I do not have any knowledge of paint, just of mech...   Jul 12 2004, 01:49 PM
djm914-6   I too am only going by what I read and what I...   Jul 12 2004, 01:54 PM
groot   I'm in the middle of putting epoxy primer on m...   Jul 12 2004, 01:59 PM
newdeal2   Bondo is just a product name...there are much bett...   Jul 12 2004, 02:00 PM
Brett W   Alright here is the skinny: I have used all of th...   Jul 12 2004, 03:24 PM
newdeal2   :agree: After speaking to my body shop it is wit...   Jul 12 2004, 04:04 PM
brant   ...   Jul 12 2004, 04:19 PM
groot   Click on: http://www.ppg.com/refinishftpsite/docs...   Jul 13 2004, 10:11 AM
freezing14   after managing to get a hold on one of the technic...   Jul 13 2004, 11:04 AM
newdeal2   I have to disagree...the pro I have talked too sta...   Jul 13 2004, 01:25 PM
tdgray   I have done both.. over metal and over primer. I w...   Jul 13 2004, 02:57 PM
TBrads914/6   Old school: filler on metal (can't feather it ...   Jul 13 2004, 06:33 PM
Mark Henry   Before I went to just engines i used to do full re...   Jul 13 2004, 10:16 PM
vortrex   I've heard filler over primer also, usually ov...   Jul 13 2004, 10:57 PM
tdgray
- Lo-Fi Version Time is now: 8th July 2025 - 02:56 PM
