freezing14 |
freezing14 ![]() ![]() Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 ![]() |
i am finaly done fixing the swiss cheeze on the car , it is all gone, i will be soda blasting the car within a couple of days and i will be putting the primer on myself to be able to do the most of the body work myself and i have looked into the different primer and now i am confused?? (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) i will be using the omni line of paint from PPG and there is a couple of different primer--
the epoxy etch, but it contains chrome ( very toxic) so reject as i have a home made paint booth the regular epoxy but apparently it is not sandable ( wtf it means) then there is the high build 1K no epoxy ?? then the high build 2K epoxy the car is strait and very little pitting on the outside i had to joint the quater panel half way and i did a couple of patch but they are but weld so very little bondo what is the best price versus quality way to do?? I know i have to primer, putty, primer and then paint , which one should I use for which thanks you very much for your help (IMG:style_emoticons/default/headbang.gif) |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,010 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
head over to:
http://www.autobodystore.com/ and they have a great webboard you can search.... talk to your paint shop that you intend to buy the product from and follow their directions... I think your going to want a catalysed primer.. I've used omni cataylized and non-catalyzed before... Is it the MTK? can't remember what their newer version is called, but the guy that is selling you the top coat will know for sure... brant |
Lo-Fi Version | Time is now: 8th July 2025 - 02:51 PM |
