> Dry sump systems
moggy
post Jun 22 2013, 02:38 AM
It's time I moved out of the dark ages and got myself a dry sump system on the rallycar. What's everyone using? Any pictures of installations? especially with the stock cooling. My concern is that I'll have to do some major surgery on the fan shroud (4 cylinder engine) as any dry sump pump will sit so far proud that I'll have to cut a hole in the fan shroud. Really interested to see what everyone has done. (IMG:style_emoticons/default/beerchug.gif)
john rogers
post Jul 7 2013, 07:28 PM
Some things to remember about dry sump systems.
- They are not cheap, the use of braided Earl's -12 lines alone is a large expense. A top of the line cooler is not cheap either.
- The suction pump has to be higher capacity that the pressure pump and when you get above 4K RPM the crankcase will usually become under a vacuum. The valve cover gaskets will need to be held in place or they can get sucked loose so most times a vent is added to each valve cover.
- The oil level in the sump tank has to be figured when hot and level, much like a regular Porsche dry sump in a 911, otherwise the oil will find a way to blow out the sump tank.
- Which brings us to a puke tank, it needs to be large and able to handle blow by if the oil level gets too high.
Good luck
moggy
post Jul 8 2013, 02:39 PM
QUOTE(john rogers @ Jul 7 2013, 05:28 PM) *
Good luck
Thanks John
I've ordered a pump from Thorsten Pieper (similar design to CB one but bigger and better). I already have a quality front mount cooler and remote filter in the front boot. I can't buy an off the shelf tank (3 gallon) that will fit anywhere suitable, so I'm having someone make me a custom one that will fit in the engine bay just behind my seat.
moggy   Dry sump systems   Jun 22 2013, 02:38 AM
tomeric914   I was going to go dry sump with the four, but swit...   Jun 22 2013, 12:15 PM
McMark   I bought a TypeI Auto-Stick oil pump with fits in ...   Jun 22 2013, 05:44 PM
Matt Romanowski   I would be concerned with the scavenge on that pum...   Jun 22 2013, 07:22 PM
moggy   Thanks for the feedback so far guys. I've done...   Jun 23 2013, 03:33 PM
bam914   Get a pump from Thorsten Pieper. It is a 2 stage ...   Jun 23 2013, 04:37 PM
moggy   Get a pump from Thorsten Pieper. It is a 2 stage...   Jun 23 2013, 11:59 PM
Racer Chris   I use the CB 2 rotor pumps. The front inlet and ou...   Jun 23 2013, 04:39 PM
Randal   I use the CB 2 rotor pumps. The front inlet and o...   Jun 23 2013, 08:25 PM
dlestep   Do you get additional HP by running a dry sump oi...   Jun 23 2013, 08:46 PM
bam914   It was over $400.00. He is in Germany. You ...   Jun 24 2013, 09:43 AM
moggy   It was over $400.00. He is in Germany. You...   Jun 25 2013, 01:06 AM
moggy   I'm going for the Thorsten Pieper pump (Thanks...   Jun 28 2013, 12:00 PM
moggy   It was over $400.00. He is in Germany. You...   Dec 8 2013, 02:59 PM
bam914   It was over $400.00. He is in Germany. Yo...   Dec 9 2013, 09:44 PM
moggy   Never got to that point. Sorry No worries :bee...   Dec 11 2013, 05:39 AM
r_towle   If you go to the 911 cooling shroud, everything fi...   Jun 24 2013, 03:40 PM
moggy   Quick question..... What do I do with the current...   Jun 28 2013, 12:42 PM
moggy   Quick question..... What do I do with the curren...   Jul 8 2013, 02:42 PM
yeahmag   My build shows most everything you need to know: ...   Jun 28 2013, 05:27 PM
stugray   Anyone have complete diagrams? I have read most o...   Jul 5 2013, 08:24 PM
yeahmag   RE: Dry sump systems   Jul 6 2013, 09:01 AM
stugray   That helps but it doesnt show the other half. That...   Jul 6 2013, 12:02 PM
john rogers   Some things to remember about dry sump systems. - ...   Jul 7 2013, 07:28 PM
moggy   Some things to remember about dry sump systems. -...   Jul 8 2013, 02:39 PM
Racer Chris   You will need to loop them together, not block the...   Jul 8 2013, 03:54 PM
moggy   You will need to loop them together, not block th...   Jul 9 2013, 03:17 PM
moggy   You will need to loop them together, not block th...   Jul 9 2013, 04:09 PM
Racer Chris   That looks like just the ticket.   Jul 9 2013, 06:28 PM
Borderline   It's been a while since I did my engine build,...   Dec 11 2013, 12:30 PM
yeahmag   I used a single peace of strong angle iron and onl...   Dec 11 2013, 12:48 PM
moggy   Aaron - I looked at that option but decided agains...   Dec 12 2013, 09:02 AM
pcar916   ... as well you'll have to calculate the prope...   Dec 12 2013, 09:31 AM
- Lo-Fi Version Time is now: 23rd October 2025 - 08:17 PM
