> paint info needed, what is the best primer to use
freezing14
post Jul 12 2004, 11:51 AM
freezing14
i am finaly done fixing the swiss cheeze on the car , it is all gone, i will be soda blasting the car within a couple of days and i will be putting the primer on myself to be able to do the most of the body work myself and i have looked into the different primer and now i am confused?? (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) i will be using the omni line of paint from PPG and there is a couple of different primer--
the epoxy etch, but it contains chrome ( very toxic) so reject as i have a home made paint booth
the regular epoxy but apparently it is not sandable ( wtf it means)
then there is the high build 1K no epoxy ??
then the high build 2K epoxy
the car is strait and very little pitting on the outside i had to joint the quater panel half way and i did a couple of patch but they are but weld so very little bondo
what is the best price versus quality way to do??
I know i have to primer, putty, primer and then paint , which one should I use for which
thanks you very much for your help
newdeal2
post Jul 12 2004, 04:04 PM
Unregistered
After speaking to my body shop it is with out question:
"Always apply Filler products to bare metal. Never apply over primer."
If you miss a spot after priming you must go back to the metal for the best result or down the road you will have problems.
I have been using Dupont Chroma Base and Chroma Clear for about 8 years on all of my models. I find it is very easy to work with but my body shop thinks the clear products don't harden off enough. Stay away from PPG.
freezing14   paint info needed   Jul 12 2004, 11:51 AM
newdeal2   I will be priming my GT6 this week [it's down ...   Jul 12 2004, 11:58 AM
newdeal2   PS...be very carefull what you use to blast the ca...   Jul 12 2004, 12:02 PM
djm914-6   Ive read that epoxy primer is the best to use over...   Jul 12 2004, 12:20 PM
newdeal2   I'm not questioning your knowledge of the subj...   Jul 12 2004, 01:42 PM
brant   head over to: http://www.autobodystore.com/ and ...   Jul 12 2004, 01:48 PM
freezing14   I do not have any knowledge of paint, just of mech...   Jul 12 2004, 01:49 PM
djm914-6   I too am only going by what I read and what I...   Jul 12 2004, 01:54 PM
groot   I'm in the middle of putting epoxy primer on m...   Jul 12 2004, 01:59 PM
newdeal2   Bondo is just a product name...there are much bett...   Jul 12 2004, 02:00 PM
Brett W   Alright here is the skinny: I have used all of th...   Jul 12 2004, 03:24 PM
newdeal2   :agree: After speaking to my body shop it is wit...   Jul 12 2004, 04:04 PM
brant   ...   Jul 12 2004, 04:19 PM
groot   Click on: http://www.ppg.com/refinishftpsite/docs...   Jul 13 2004, 10:11 AM
freezing14   after managing to get a hold on one of the technic...   Jul 13 2004, 11:04 AM
newdeal2   I have to disagree...the pro I have talked too sta...   Jul 13 2004, 01:25 PM
tdgray   I have done both.. over metal and over primer. I w...   Jul 13 2004, 02:57 PM
TBrads914/6   Old school: filler on metal (can't feather it ...   Jul 13 2004, 06:33 PM
Mark Henry   Before I went to just engines i used to do full re...   Jul 13 2004, 10:16 PM
vortrex   I've heard filler over primer also, usually ov...   Jul 13 2004, 10:57 PM
tdgray
- Lo-Fi Version Time is now: 8th July 2025 - 03:08 PM
