| malcolm2 |
Jul 9 2013, 08:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
My 1st post of the same subject
Summary: rescued 75 with L-jet: HAM repaired heads, 9550 cam from Type 4 store, All engine harnesses from Bowlsby, 96mm pistons from type 4 store (1911cc), Injectors cleaned by Cruzin Performance...(twice), engine sat for 12 mths while I worked on rust from sitting for 10 years, etc... A couple weekends ago I went thru EXTENSIVE troubleshooting with Timothy_ND29 (huge thank you (IMG:style_emoticons/default/beerchug.gif) ), but the engine would not fire. That is the above link.... We ended up determining that my fresh injectors were clogged cause they sat for 12+ months. CruzinPerformance "woke them up" last week and they arrived back here today. I don't know what else to test: EVERYTHING operates, EVERYTHING: 1. 35+ psi fuel pressure 2. Starter turns engine with the key. 3. Noid lights at all injectors LIGHT 4. Spark plugs at all plugs SPARK 5. Injectors squirt (tested 1 and 2) 6. Valves actually move (I had to know it the damn thing was moving on the inside) Here is the big one: After installing the fresh injectors, I did hear a slight fire, or poot of a backfire. Then nothing. I took the air box off and sprayed starting fluid in the intake while trying to start and STILL NOTHING. (IMG:style_emoticons/default/hissyfit.gif) Question 1: How much spark do I need? Question 2: How much squirt do I need? Both happened, but they seemed weak, or small. Need more help, I feel like the doctor that left a sponge in his patient.... (IMG:style_emoticons/default/confused24.gif) |
| timothy_nd28 |
Jul 9 2013, 10:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
Excellent, with the red mark between the v knotch and you have rocker slack at number one cylinder, says we are good. Where ever you rotor is pointing, put the number one plug wire on it. Then 4,3,2 wires in a clockwise fashion, then start your beast.
malcolm2 75 LJet will not fire Jul 9 2013, 08:09 PM
jim_hoyland Is the brown wire from the dual relay grounded ? Jul 9 2013, 08:14 PM
malcolm2
... Jul 9 2013, 08:23 PM
timothy_nd28 Sounds like the FI is doing its job. However the t... Jul 9 2013, 08:15 PM
malcolm2
Sounds like the FI is doing its job. However the ... Jul 9 2013, 08:20 PM
malcolm2
Sounds like the FI is doing its job. However the ... Jul 9 2013, 08:24 PM
davesprinkle
Sounds like the FI is doing its job. However the... Jul 9 2013, 08:57 PM
timothy_nd28 No need, your FI is working. We went thru the whol... Jul 9 2013, 08:28 PM
malcolm2
No need, your FI is working. We went thru the who... Jul 9 2013, 08:42 PM
Mblizzard I had a similar problem many years ago. It turned ... Jul 9 2013, 08:43 PM
malcolm2
I had a similar problem many years ago. It turned... Jul 9 2013, 08:45 PM
Mblizzard
I had a similar problem many years ago. It turne... Jul 9 2013, 09:18 PM
timothy_nd28 K, can you remove the valve cover and wiggle the r... Jul 9 2013, 08:47 PM
malcolm2
K, can you remove the valve cover and wiggle the ... Jul 9 2013, 08:57 PM
malcolm2
[quote name='timothy_nd28' post='1892665' date='J... Jul 9 2013, 09:13 PM
timothy_nd28
[quote name='timothy_nd28' post='1892665' date='J... Jul 9 2013, 09:17 PM
malcolm2
You should have valve lash wiggle on both rockers... Jul 9 2013, 09:25 PM
The Cabinetmaker
[quote name='timothy_nd28' post='1892665' date='J... Jul 10 2013, 09:06 AM
timothy_nd28 Don't put anything into the spark plug hole Jul 9 2013, 09:22 PM
Mblizzard Verify that you #1 viewed from sitting in the car... Jul 9 2013, 09:28 PM
timothy_nd28 I find it easy to put the passenger rear wheel on ... Jul 9 2013, 09:28 PM
malcolm2
I find it easy to put the passenger rear wheel on... Jul 9 2013, 09:42 PM
timothy_nd28 It's dangerous, anything you put in that spark... Jul 9 2013, 09:52 PM
malcolm2
It's dangerous, anything you put in that spar... Jul 9 2013, 09:57 PM
malcolm2
[quote name='timothy_nd28' post='1892703' date='J... Jul 9 2013, 10:07 PM
timothy_nd28 Never mind the position of the dizzy's rotor f... Jul 9 2013, 10:07 PM
malcolm2
Never mind the position of the dizzy's rotor ... Jul 9 2013, 10:14 PM
malcolm2
Excellent, with the red mark between the v knotch... Jul 9 2013, 10:26 PM
malcolm2
Excellent, with the red mark between the v knotc... Jul 9 2013, 10:50 PM
timothy_nd28 Spin the dizzy so it's pointing at the number ... Jul 9 2013, 10:28 PM
timothy_nd28 Which way did you turn the distributor to align th... Jul 9 2013, 10:52 PM
malcolm2
Which way did you turn the distributor to align t... Jul 9 2013, 10:56 PM
timothy_nd28 Try moving the dizzy counter clockwise a smidge an... Jul 9 2013, 11:01 PM
malcolm2
Try moving the dizzy counter clockwise a smidge a... Jul 9 2013, 11:09 PM
timothy_nd28 Lets start over. Line up the red mark with the v k... Jul 9 2013, 11:12 PM
malcolm2
Lets start over. Line up the red mark with the v ... Jul 9 2013, 11:12 PM
malcolm2
Lets start over. Line up the red mark with the v... Jul 9 2013, 11:26 PM
Bob L. :popcorn: Jul 9 2013, 11:21 PM
timothy_nd28 Can you post a pic of the rotor, so we can see whi... Jul 9 2013, 11:28 PM
malcolm2
Can you post a pic of the rotor, so we can see wh... Jul 9 2013, 11:35 PM
timothy_nd28 Ok, put the cap on and put only the number one plu... Jul 9 2013, 11:38 PM
malcolm2
Ok, put the cap on and put only the number one pl... Jul 9 2013, 11:44 PM
timothy_nd28 With your volt meter, set it to resistance. Measur... Jul 9 2013, 11:49 PM
malcolm2
With your volt meter, set it to resistance. Measu... Jul 10 2013, 12:00 AM
timothy_nd28 The vacuum can may be limiting the rotation. Try m... Jul 10 2013, 12:03 AM
malcolm2
The vacuum can may be limiting the rotation. Try ... Jul 10 2013, 12:12 AM
timothy_nd28 I'm sorry, I'm not thinking here. The roto... Jul 10 2013, 12:16 AM
malcolm2
I'm sorry, I'm not thinking here. The rot... Jul 10 2013, 12:29 AM
timothy_nd28 I'm turning in for the night, lets pick this u... Jul 10 2013, 12:31 AM
malcolm2
I'm turning in for the night, lets pick this ... Jul 10 2013, 12:33 AM
timothy_nd28 After re-reading part of this thread I made a assu... Jul 10 2013, 08:30 AM
malcolm2
After re-reading part of this thread I made a ass... Jul 10 2013, 12:04 PM
Java2570 :agree:
I just went through a similar issue wi... Jul 10 2013, 09:31 AM
malcolm2
:agree:
I just went through a similar issue w... Jul 10 2013, 11:50 AM
Java2570
:agree:
I just went through a similar issue ... Jul 10 2013, 12:23 PM
stugray
No, you should not need to pull the drive gear.
... Jul 10 2013, 11:14 AM
malcolm2 I have come up with a way to manually rotate the e... Jul 10 2013, 06:08 PM
The Cabinetmaker Forget the mark you made. Where does the rotor poi... Jul 10 2013, 06:19 PM
malcolm2
Forget the mark you made. Where does the rotor po... Jul 10 2013, 06:31 PM
timothy_nd28 Number one plug wire still on the right rear tower... Jul 10 2013, 07:08 PM
malcolm2
Number one plug wire still on the right rear towe... Jul 10 2013, 07:17 PM
The Cabinetmaker
Number one plug wire still on the right rear tow... Jul 10 2013, 08:04 PM
Bob L.
[quote name='malcolm2' post='1893198' date='Jul 1... Jul 10 2013, 08:09 PM
malcolm2
[quote name='malcolm2' post='1893198' date='Jul 1... Jul 10 2013, 08:13 PM
stugray When you think you are at TDC based on valves, che... Jul 10 2013, 07:10 PM
malcolm2
When you think you are at TDC based on valves, ch... Jul 10 2013, 07:39 PM
timothy_nd28 Move the number one at the right rear tower and st... Jul 10 2013, 07:50 PM
malcolm2
Move the number one at the right rear tower and s... Jul 10 2013, 08:09 PM
malcolm2 should I go ahead and adjust the valves on the dri... Jul 10 2013, 07:56 PM
timothy_nd28 Are you using aluminum or chrome moly pushrods? Jul 10 2013, 07:59 PM
malcolm2
... Jul 10 2013, 08:29 PM
The Cabinetmaker
Purchased awhile back from the type 4 store and... Jul 11 2013, 07:26 AM
malcolm2
Purchased awhile back from the type 4 store an... Jul 11 2013, 09:06 AM
Mblizzard I will be traveling to Nashville next Tuesday to g... Jul 10 2013, 08:30 PM
malcolm2
I will be traveling to Nashville next Tuesday to ... Jul 10 2013, 08:35 PM
malcolm2 Timothy, what's on you mind to do next? Jul 10 2013, 08:48 PM
timothy_nd28 If you truly found TDC, I do like the idea of pull... Jul 10 2013, 08:59 PM
malcolm2
If you truly found TDC, I do like the idea of pul... Jul 10 2013, 09:09 PM
timothy_nd28 I'll be honest, every time I split the case, I... Jul 10 2013, 09:19 PM
malcolm2
I'll be honest, every time I split the case, ... Jul 10 2013, 09:54 PM
timothy_nd28 The intake valve should be last to move before tdc... Jul 10 2013, 09:27 PM
malcolm2
The intake valve should be last to move before td... Jul 10 2013, 09:31 PM
stugray I just went through this entire process.
Can you ... Jul 10 2013, 09:39 PM
timothy_nd28 You may need to pry the hold down bracket while pu... Jul 10 2013, 09:59 PM
stugray Read my post above first, and the link then IF tha... Jul 10 2013, 10:00 PM
malcolm2
Read my post above first, and the link then IF th... Jul 11 2013, 05:50 AM
The Cabinetmaker There is no white mark unless someone else made on... Jul 11 2013, 06:51 AM
malcolm2
There is no white mark unless someone else made o... Jul 11 2013, 09:02 AM
timothy_nd28 :agree: Jul 11 2013, 07:03 AM
The Cabinetmaker Ok, I understand. you will be ok. just remember th... Jul 11 2013, 09:12 AM
stugray
Ok, so there might not be white paint on the mar... Jul 11 2013, 09:14 AM
stugray I just did a search and found some say that the ma... Jul 11 2013, 09:38 AM
The Cabinetmaker If it were my old ass, I'd just go with option... Jul 11 2013, 09:44 AM
Java2570 Factory notch will be at the top of the trans @ TD... Jul 11 2013, 09:47 AM
malcolm2 So to verify TDC, I need to look for or feel for t... Jul 11 2013, 10:17 AM
stugray Confusion resolved: I have the notch (visible at t... Jul 11 2013, 10:27 AM
stugray
I followed Jake's video and installed the dr... Jul 11 2013, 10:31 AM
Bob L. Malcolm,
Have you tried the #1 wire on the right r... Jul 11 2013, 10:54 AM
Bartlett 914 Did you ever check your compression? Jul 11 2013, 11:02 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:38 PM |
