> 75 LJet will not fire, PHASE 2: still not starting...Phase 3: not idling, PHASE 4: fine tune!
malcolm2
post Jul 9 2013, 08:09 PM
My 1st post of the same subject
Summary: rescued 75 with L-jet: HAM repaired heads, 9550 cam from Type 4 store, All engine harnesses from Bowlsby, 96mm pistons from type 4 store (1911cc), Injectors cleaned by Cruzin Performance...(twice), engine sat for 12 mths while I worked on rust from sitting for 10 years, etc...
A couple weekends ago I went thru EXTENSIVE troubleshooting with Timothy_ND29 (huge thank you (IMG:style_emoticons/default/beerchug.gif) ), but the engine would not fire. That is the above link....
We ended up determining that my fresh injectors were clogged cause they sat for 12+ months. CruzinPerformance "woke them up" last week and they arrived back here today. I don't know what else to test: EVERYTHING operates, EVERYTHING:
1. 35+ psi fuel pressure
2. Starter turns engine with the key.
3. Noid lights at all injectors LIGHT
4. Spark plugs at all plugs SPARK
5. Injectors squirt (tested 1 and 2)
6. Valves actually move (I had to know it the damn thing was moving on the inside)
Here is the big one: After installing the fresh injectors, I did hear a slight fire, or poot of a backfire. Then nothing. I took the air box off and sprayed starting fluid in the intake while trying to start and STILL NOTHING. (IMG:style_emoticons/default/hissyfit.gif)
Question 1: How much spark do I need?
Question 2: How much squirt do I need?
Both happened, but they seemed weak, or small.
Need more help, I feel like the doctor that left a sponge in his patient.... (IMG:style_emoticons/default/confused24.gif)
timothy_nd28
post Jul 9 2013, 11:49 PM
With your volt meter, set it to resistance. Measure the resistance between the middle socket on the cap to the end of the number one plug wire. Spin the dizzy clockwise till you have infinite resistance then spin the dizzy back counter clockwise right to the point where you first get a low resistance.
malcolm2
post Jul 10 2013, 12:00 AM
QUOTE(timothy_nd28 @ Jul 10 2013, 12:49 AM) *
Either I am doing this wrong, or I found something.... my meter never moved. I am basically checking continuity thru the points and the button, correct? I then checked the #1 wire itself and got continuity, but never got the meter to read thru the center connection.
Right or Wrong?
malcolm2   75 LJet will not fire   Jul 9 2013, 08:09 PM
jim_hoyland   Is the brown wire from the dual relay grounded ?   Jul 9 2013, 08:14 PM
malcolm2   Is the brown wire from the dual relay grounded ? ...   Jul 9 2013, 08:23 PM
timothy_nd28   Sounds like the FI is doing its job. However the t...   Jul 9 2013, 08:15 PM
malcolm2   Sounds like the FI is doing its job. However the ...   Jul 9 2013, 08:20 PM
malcolm2   Sounds like the FI is doing its job. However the ...   Jul 9 2013, 08:24 PM
davesprinkle   Sounds like the FI is doing its job. However the...   Jul 9 2013, 08:57 PM
timothy_nd28   No need, your FI is working. We went thru the whol...   Jul 9 2013, 08:28 PM
malcolm2   No need, your FI is working. We went thru the who...   Jul 9 2013, 08:42 PM
Mblizzard   I had a similar problem many years ago. It turned ...   Jul 9 2013, 08:43 PM
malcolm2   I had a similar problem many years ago. It turned...   Jul 9 2013, 08:45 PM
Mblizzard   I had a similar problem many years ago. It turne...   Jul 9 2013, 09:18 PM
timothy_nd28   K, can you remove the valve cover and wiggle the r...   Jul 9 2013, 08:47 PM
malcolm2   K, can you remove the valve cover and wiggle the ...   Jul 9 2013, 08:57 PM
malcolm2   [quote name='timothy_nd28' post='1892665' date='J...   Jul 9 2013, 09:13 PM
timothy_nd28   [quote name='timothy_nd28' post='1892665' date='J...   Jul 9 2013, 09:17 PM
malcolm2   You should have valve lash wiggle on both rockers...   Jul 9 2013, 09:25 PM
The Cabinetmaker   [quote name='timothy_nd28' post='1892665' date='J...   Jul 10 2013, 09:06 AM
timothy_nd28   Don't put anything into the spark plug hole   Jul 9 2013, 09:22 PM
Mblizzard   Verify that you #1 viewed from sitting in the car...   Jul 9 2013, 09:28 PM
timothy_nd28   I find it easy to put the passenger rear wheel on ...   Jul 9 2013, 09:28 PM
malcolm2   I find it easy to put the passenger rear wheel on...   Jul 9 2013, 09:42 PM
timothy_nd28   It's dangerous, anything you put in that spark...   Jul 9 2013, 09:52 PM
malcolm2   It's dangerous, anything you put in that spar...   Jul 9 2013, 09:57 PM
malcolm2   [quote name='timothy_nd28' post='1892703' date='J...   Jul 9 2013, 10:07 PM
timothy_nd28   Never mind the position of the dizzy's rotor f...   Jul 9 2013, 10:07 PM
malcolm2   Never mind the position of the dizzy's rotor ...   Jul 9 2013, 10:14 PM
timothy_nd28   Excellent, with the red mark between the v knotch ...   Jul 9 2013, 10:23 PM
malcolm2   Excellent, with the red mark between the v knotch...   Jul 9 2013, 10:26 PM
malcolm2   Excellent, with the red mark between the v knotc...   Jul 9 2013, 10:50 PM
timothy_nd28   Spin the dizzy so it's pointing at the number ...   Jul 9 2013, 10:28 PM
timothy_nd28   Which way did you turn the distributor to align th...   Jul 9 2013, 10:52 PM
malcolm2   Which way did you turn the distributor to align t...   Jul 9 2013, 10:56 PM
timothy_nd28   Try moving the dizzy counter clockwise a smidge an...   Jul 9 2013, 11:01 PM
malcolm2   Try moving the dizzy counter clockwise a smidge a...   Jul 9 2013, 11:09 PM
timothy_nd28   Lets start over. Line up the red mark with the v k...   Jul 9 2013, 11:12 PM
malcolm2   Lets start over. Line up the red mark with the v ...   Jul 9 2013, 11:12 PM
malcolm2   Lets start over. Line up the red mark with the v...   Jul 9 2013, 11:26 PM
Bob L.   :popcorn:   Jul 9 2013, 11:21 PM
timothy_nd28   Can you post a pic of the rotor, so we can see whi...   Jul 9 2013, 11:28 PM
malcolm2   Can you post a pic of the rotor, so we can see wh...   Jul 9 2013, 11:35 PM
timothy_nd28   Ok, put the cap on and put only the number one plu...   Jul 9 2013, 11:38 PM
malcolm2   Ok, put the cap on and put only the number one pl...   Jul 9 2013, 11:44 PM
timothy_nd28   With your volt meter, set it to resistance. Measur...   Jul 9 2013, 11:49 PM
malcolm2   With your volt meter, set it to resistance. Measu...   Jul 10 2013, 12:00 AM
timothy_nd28   The vacuum can may be limiting the rotation. Try m...   Jul 10 2013, 12:03 AM
malcolm2   The vacuum can may be limiting the rotation. Try ...   Jul 10 2013, 12:12 AM
timothy_nd28   I'm sorry, I'm not thinking here. The roto...   Jul 10 2013, 12:16 AM
malcolm2   I'm sorry, I'm not thinking here. The rot...   Jul 10 2013, 12:29 AM
timothy_nd28   I'm turning in for the night, lets pick this u...   Jul 10 2013, 12:31 AM
malcolm2   I'm turning in for the night, lets pick this ...   Jul 10 2013, 12:33 AM
timothy_nd28   After re-reading part of this thread I made a assu...   Jul 10 2013, 08:30 AM
malcolm2   After re-reading part of this thread I made a ass...   Jul 10 2013, 12:04 PM
Java2570   :agree: I just went through a similar issue wi...   Jul 10 2013, 09:31 AM
malcolm2   :agree: I just went through a similar issue w...   Jul 10 2013, 11:50 AM
Java2570   :agree: I just went through a similar issue ...   Jul 10 2013, 12:23 PM
stugray   No, you should not need to pull the drive gear. ...   Jul 10 2013, 11:14 AM
malcolm2   I have come up with a way to manually rotate the e...   Jul 10 2013, 06:08 PM
The Cabinetmaker   Forget the mark you made. Where does the rotor poi...   Jul 10 2013, 06:19 PM
malcolm2   Forget the mark you made. Where does the rotor po...   Jul 10 2013, 06:31 PM
timothy_nd28   Number one plug wire still on the right rear tower...   Jul 10 2013, 07:08 PM
malcolm2   Number one plug wire still on the right rear towe...   Jul 10 2013, 07:17 PM
The Cabinetmaker   Number one plug wire still on the right rear tow...   Jul 10 2013, 08:04 PM
Bob L.   [quote name='malcolm2' post='1893198' date='Jul 1...   Jul 10 2013, 08:09 PM
malcolm2   [quote name='malcolm2' post='1893198' date='Jul 1...   Jul 10 2013, 08:13 PM
stugray   When you think you are at TDC based on valves, che...   Jul 10 2013, 07:10 PM
malcolm2   When you think you are at TDC based on valves, ch...   Jul 10 2013, 07:39 PM
timothy_nd28   Move the number one at the right rear tower and st...   Jul 10 2013, 07:50 PM
malcolm2   Move the number one at the right rear tower and s...   Jul 10 2013, 08:09 PM
malcolm2   should I go ahead and adjust the valves on the dri...   Jul 10 2013, 07:56 PM
timothy_nd28   Are you using aluminum or chrome moly pushrods?   Jul 10 2013, 07:59 PM
malcolm2   Are you using aluminum or chrome moly pushrods? ...   Jul 10 2013, 08:29 PM
The Cabinetmaker   Purchased awhile back from the type 4 store and...   Jul 11 2013, 07:26 AM
malcolm2   Purchased awhile back from the type 4 store an...   Jul 11 2013, 09:06 AM
Mblizzard   I will be traveling to Nashville next Tuesday to g...   Jul 10 2013, 08:30 PM
malcolm2   I will be traveling to Nashville next Tuesday to ...   Jul 10 2013, 08:35 PM
malcolm2   Timothy, what's on you mind to do next?   Jul 10 2013, 08:48 PM
timothy_nd28   If you truly found TDC, I do like the idea of pull...   Jul 10 2013, 08:59 PM
malcolm2   If you truly found TDC, I do like the idea of pul...   Jul 10 2013, 09:09 PM
timothy_nd28   I'll be honest, every time I split the case, I...   Jul 10 2013, 09:19 PM
malcolm2   I'll be honest, every time I split the case, ...   Jul 10 2013, 09:54 PM
timothy_nd28   The intake valve should be last to move before tdc...   Jul 10 2013, 09:27 PM
malcolm2   The intake valve should be last to move before td...   Jul 10 2013, 09:31 PM
stugray   I just went through this entire process. Can you ...   Jul 10 2013, 09:39 PM
timothy_nd28   You may need to pry the hold down bracket while pu...   Jul 10 2013, 09:59 PM
stugray   Read my post above first, and the link then IF tha...   Jul 10 2013, 10:00 PM
malcolm2   Read my post above first, and the link then IF th...   Jul 11 2013, 05:50 AM
The Cabinetmaker   There is no white mark unless someone else made on...   Jul 11 2013, 06:51 AM
malcolm2   There is no white mark unless someone else made o...   Jul 11 2013, 09:02 AM
timothy_nd28   :agree:   Jul 11 2013, 07:03 AM
The Cabinetmaker   Ok, I understand. you will be ok. just remember th...   Jul 11 2013, 09:12 AM
stugray   Ok, so there might not be white paint on the mar...   Jul 11 2013, 09:14 AM
stugray   I just did a search and found some say that the ma...   Jul 11 2013, 09:38 AM
The Cabinetmaker   If it were my old ass, I'd just go with option...   Jul 11 2013, 09:44 AM
Java2570   Factory notch will be at the top of the trans @ TD...   Jul 11 2013, 09:47 AM
malcolm2   So to verify TDC, I need to look for or feel for t...   Jul 11 2013, 10:17 AM
stugray   Confusion resolved: I have the notch (visible at t...   Jul 11 2013, 10:27 AM
stugray   I followed Jake's video and installed the dr...   Jul 11 2013, 10:31 AM
Bob L.   Malcolm, Have you tried the #1 wire on the right r...   Jul 11 2013, 10:54 AM
Bartlett 914   Did you ever check your compression?   Jul 11 2013, 11:02 AM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 03:31 PM
