| billh1963 |
Jun 28 2013, 06:12 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,431 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
I don't have any helpers this weekend and want to check for spark at the spark plugs (or at least spark from the coil). I don't have a remote starter so what options do I have for testing (seeing) the spark?
Probably a simple problem but I'm at a loss..... UPDATE 7-26: The cause of my problem was a shorted out tachometer! Once the tachometer was unplugged, I had ignition. A replacement tach was put in and the car runs fine. I would have never thought of that..... |
| billh1963 |
Jul 26 2013, 02:10 PM
Problem solved...see update in first post
| Bartlett 914 |
Jul 26 2013, 04:20 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Problem solved...see update in first post Shorted Tach? Wow I wouldn't have gone there first that's for sure. There is probably an electrolytic cap at the input that went bad. It would act like a shorted condensor which is also a capacitor. Electrolytic caps have a limited life span. |
billh1963 UPDATE- Ignition Solved! If you are working by yourself, how can you check the ignition? Jun 28 2013, 06:12 PM
914_teener
I don't have any helpers this weekend and wan... Jun 28 2013, 06:29 PM
billh1963
I don't have any helpers this weekend and wa... Jun 28 2013, 06:36 PM
r_towle Distributor cover off
Rotor off
Key on in ignition... Jun 28 2013, 06:33 PM
stugray you can also:
pull plug wire, hook to extra spark... Jun 28 2013, 06:41 PM
malcolm2 I just bought a cool tool from harbor freight. ... Jun 28 2013, 07:21 PM
brant A remote starter switch is 10 or so dollars at the... Jun 28 2013, 07:45 PM
worn
I don't have any helpers this weekend and wan... Jun 28 2013, 09:54 PM
Dave_Darling Brant's got the best answer--remote starter sw... Jun 28 2013, 10:02 PM
The Cabinetmaker Another here for a remote switch. Its just a momen... Jun 29 2013, 04:03 PM
McMark Timing light. ;) If it flashes, it sparked. Jun 29 2013, 04:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:28 AM |
