> engine tin removal
pda914
post Jul 28 2013, 12:45 PM
Is it at all possible to remove the engine tin over the oil cooler and temp sensor without dropping the engine? I need to get at both the oil cooler top and I need to replace the temperare sensor.
If so what should I look out for?
stugray
post Jul 28 2013, 04:39 PM
Why would you :
be replacing it with a type K themocouple together with a themocouple amp with offset correction and some op-amps to make it act like an thermister with a negative temp curve that the megasquirt expects.
why wouldnt you just replace it with a new thermistor "that meagasquirt expects" that is not grounded to the engine case like the stock version?
Sounds like a lot less work.
Take a stock CHT, and drill out the core and replace it with a two wire (or 4-wire if you are really anal) and hook it up.
Converting from thermocouple back to thermistor-like thing sounds like an experiment that isnt required.
Stu
pda914
post Jul 28 2013, 05:19 PM
I will be replacing it with a type K themocouple together with a themocouple amp with offset correction and some op-amps to make it act like an thermister with a negative temp curve that the megasquirt expects. This will isolate the temp sensor from the engine ground that electrically noisy.
Thermisters are qustionable above 300F i think . A thermocouple is a nice linear sensor but the only issue is making something with a postive thermnal coefficent to be negative.
QUOTE(stugray @ Jul 28 2013, 05:39 PM) *
Why would you :
Stu
pda914
post Jul 28 2013, 05:36 PM
I thnk drilling out an old thermister and tring to glue it back together with some sort of epoxy that can transfer heat in order to get an isolated ground sensor is questionable in its final performance. I'd go the electronics route and take a sensor that is primarly linear from 0 to 500/deg C where a silicon based sensor is questionable after 300 def F.
The megasqiurit has a 0-5 volt AD in it Just take two op-amps with the first being non-inverting and add a gain of two after the termocouple controler giving it a postive temp coeffecient of 20mv/deg C followed by a unity gain inverting amp. Thus getting the same negative themo co-efficient as the thermister ( but linear). I don't care about lower temps so the layout is good from 40 def F to 420 deg F. The themocouple is the isolated ground type so it does not couple the engine ground to the sensor ground.
QUOTE(pda914 @ Jul 28 2013, 06:19 PM) *
Why would you :
Stu
pda914   engine tin removal   Jul 28 2013, 12:45 PM
914itis   Yes you can . You will have to remove all fuel in...   Jul 28 2013, 01:18 PM
The Cabinetmaker   Two questions. 1. Why do you need access to the ...   Jul 28 2013, 03:32 PM
pda914   I put a custom fuel injection setup and am using ...   Jul 28 2013, 04:10 PM
JamesM   I put a custom fuel injection setup and am using...   Jul 29 2013, 12:51 PM
pda914   I've noticed general 70-80 deg F swings and oc...   Jul 29 2013, 01:28 PM
JamesM   This could also be partly (or completely) due to t...   Jul 30 2013, 04:29 PM
Dave_Darling   In that case, get both sides. There's likely ...   Jul 28 2013, 04:31 PM
stugray   Why would you : why wouldnt you just replace it ...   Jul 28 2013, 04:39 PM
pda914   I will be replacing it with a type K themocouple t...   Jul 28 2013, 05:19 PM
pda914   I thnk drilling out an old thermister and tring to...   Jul 28 2013, 05:36 PM
The Cabinetmaker   Do you have an other than stock temp sender?   Jul 28 2013, 04:45 PM
pda914   yes I willl be using a thermocouple not the standa...   Jul 28 2013, 05:20 PM
stugray   True. Can the megasquirt read from this digital...   Jul 28 2013, 05:28 PM
pda914   The megasuirt uses an AD that reads from an anolog...   Jul 28 2013, 05:52 PM
stugray   I have been experimenting with the innovate TC-4. ...   Jul 28 2013, 08:14 PM
pda914   Four channels would be nice.... I hope one is rep...   Jul 28 2013, 09:40 PM
stugray   I havent hooked up the CHT yet or run the engine...   Jul 29 2013, 09:18 AM
Cap'n Krusty   Is it at all possible to remove the engine tin ov...   Jul 29 2013, 10:08 AM
The Cabinetmaker   " since that event the oil temp has been a ...   Jul 29 2013, 12:36 PM
pda914   Nope the cylinder head temp (Temp II) ...   Jul 29 2013, 01:59 PM
The Cabinetmaker   Nope the cylinder head temp (Temp II) ...   Jul 30 2013, 06:09 PM
- Lo-Fi Version Time is now: 14th July 2025 - 04:40 AM
