Tach/Turn signal conversion doesn't work, Got it working - different than the Up 'n Fixin diagram, though |
sfrenck |
Jul 28 2013, 12:01 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Used this information to install my 73 Tach into my 74 car:
You would add two wires from the emergency flasher switch to the bulbs you will use (green/black and white/ black). These are the same wires and colors leading out to the turn signal bulbs at the four corners of the car. You will modify the existing blue/white wire to extend to the other side of BOTH bulbs. The blue/white wire terminates at the flasher relay itself. Weird thing is when all the wires are connected to the hazard switch, neither indicator works for flasher or turn signal. If I unplug the L or R from the hazard switch, both turn signal indicators work as they are supposed to and one of them lights up with the hazard (whichever one I didn't unplug)? I've already switched out the hazard switch. (IMG:style_emoticons/default/WTF.gif) Newer Update: All works if I detach the blue wire w/ white stripe from the turn indicator bulbs and instead install a ground to them. Guess I'm going with this solution rather than the diagram above indicating I need the two blue/white stripe (or, as indicated below, take the blue/white wire off of the flasher at terminal K and connect the wire to ground). |
Mike Bellis |
Jul 29 2013, 10:07 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
You could take the Blue/White wire off the relay (Terminal K)and ground it. Just the wire, not terminal K.
Make sure you have 2 wire lamp sockets and the terminals are not grounded. The sockets should only be grounded if they are single wire. In which case, just remove the wire from terminal K. |
sfrenck |
Aug 4 2013, 11:11 AM
You could take the Blue/White wire off the relay (Terminal K)and ground it. Just the wire, not terminal K. Make sure you have 2 wire lamp sockets and the terminals are not grounded. The sockets should only be grounded if they are single wire. In which case, just remove the wire from terminal K. This method works. |
Lo-Fi Version | Time is now: 8th June 2024 - 09:31 PM |
