You would add two wires from the emergency flasher switch to the bulbs you will use (green/black and white/ black). These are the same wires and colors leading out to the turn signal bulbs at the four corners of the car.
You will modify the existing blue/white wire to extend to the other side of BOTH bulbs. The blue/white wire terminates at the flasher relay itself.
Weird thing is when all the wires are connected to the hazard switch, neither indicator works for flasher or turn signal. If I unplug the L or R from the hazard switch, both turn signal indicators work as they are supposed to and one of them lights up with the hazard (whichever one I didn't unplug)? I've already switched out the hazard switch.
Newer Update: All works if I detach the blue wire w/ white stripe from the turn indicator bulbs and instead install a ground to them. Guess I'm going with this solution rather than the diagram above indicating I need the two blue/white stripe (or, as indicated below, take the blue/white wire off of the flasher at terminal K and connect the wire to ground).
